BIKELAND > FORUMS > ZX12R ZONE.com > Thread: battery NEW TOPIC NEW POLL POST REPLY
kaw12
posted October 27, 2008 04:12 PM        Edited By: kaw12 on 28 Oct 2008 00:42
battery
should new battery read at 13.4 or in the 14's?
kaw12
posted October 27, 2008 05:47 PM
bikes running on 13.4 with a new battery. I thought the volt readings should be up in the low 14's. think i may have a charging problem.
tuusinii
posted October 27, 2008 11:05 PM
Does the voltage raise when You up the revs? And was the battery fully charged when You put it in?
posted October 28, 2008 01:06 AM
13.4V is ok at idle w/headlights on. at 5000 it should be 14-ish
shiggsy
posted October 28, 2008 05:32 AM
I have a voltage meter hardwired directly to the battery on my bike, normal reading is 13.8v to 13.9v
kaw12
posted October 28, 2008 11:45 AM        Edited By: kaw12 on 28 Oct 2008 20:47
well the battery was fully charged before install, and the 4000 rpm test checked out great!
it never got the 14ish and with the heated grips it dropped to 11.1, but a steady 13.4 with grips off!
posted October 28, 2008 12:53 PM
As we discussed at 4K the Voltage should be in the 14's. Since you have had the Oil in the plug problem I STRONGLY Suggest removing the Stator and checking the wires with an Ohm Meter. Make sure that with the Meter set to Ohms the leeds touching read Zero (No resistance then look at each wire. You may want to completely remove the wrapping on these wires because some could be shorted out against each other. But test First before your do this then if the reading was not Zero (or close to Zero) then remove the Covering and separate the wires. look in your book it should have a Test value for this. If the wireing is good then you need a new Stator.
kaw12
posted October 28, 2008 01:21 PM        Edited By: kaw12 on 28 Oct 2008 21:22
according to the book the voltage from the stator to the reg/rec should be 85-120v and it is! however, on the ohm check were getting less than infinite!
kaw12
posted October 28, 2008 01:26 PM
the bike gets 13.4v but, as soon as i turn heated grips it drops to 11.1v.
kaw12
posted October 28, 2008 02:28 PM        Edited By: kaw12 on 28 Oct 2008 23:27
it looks to me like the stator has an open wire because the resistance is higher than .3- .5
its still charging just not charging at 14.2-15.2, so i guess i need a new stator, anyone got one?
kaw12
posted October 28, 2008 02:54 PM
thanks again vincent its always a pleasure talking with you!
flite leader
posted October 28, 2008 02:58 PM
nothing i have reads into the 14's
a battery can get "hot" & put out really hi voltage
it doesnt usually last very long
a float on a battery tender may actually be higher
the bottom line always s the cutoff in the vwehicle the battery resides in
if you put a 14+ battery in a 13.5 bike........its a 13.5 battery !!!
until your bike reads lessthan the 12's i wouldnt touch it
if you hook up an amp beter & it reads like a tach
i would be concerned otherwise NOT
good luck
bend your mind.....
or break your ass...!!
kaw12
posted October 28, 2008 03:25 PM
my correction is i took the stator out of the case and tested the leeds inside and found .6 and .7s' still higher! need a stator??
kaw12
posted October 28, 2008 03:46 PM        Edited By: kaw12 on 28 Oct 2008 23:49
johnnnyboy
08 Concours 14
posted October 28, 2008 05:33 PM
i dont have the link but theres been one on ebay for a bit have a look
tuusinii
posted October 28, 2008 11:19 PM
If You have just regular two wire ohmeter You won't get ohm reading below 0.5R because of the desing. You can test it with just measuring the resistance of the test leads on Your ohmmeter by connecting them together. Usually it read from 0.3-0.5R without You measuring nothing! So if You get a reading of 0.6-0.7R it sound good if the real resistance should be 0.3-0.5R. To measure really low voltages You would need special multimeter with 4-wire resistance measurement (it removes the resistance of You're measuring leads). If You're voltage drops to below 12V when You switch the heater on it is probably too powerfull. Do You have any other extra loads on the bike? Like bigger wattage bulps or any other things. One thing to check carefully is the plug and wire if You have had the heating problem with oil.
kaw12
posted October 29, 2008 06:04 AM
i have the grips running through the centech aux. box, grips on swithed, whistler cruisader radar detector on switched, and scorpio alarm on constant. the centech is running straight to the battery,,except for the switched and that runs somewhere where i tapped in to open the circuit when the key is turned on!!
posted October 29, 2008 02:13 PM
My Ohm Meter reads "0" when I touch the leads because it is a direct connection and there is "0" Resistance!
kaw12
posted October 29, 2008 02:53 PM
good news! i re-wired everything that's installed on the bike and i think i also found a loose connected(wasn't plugged in all the way) . i also installed a relay to the centech! now i'm getting 14v even with the grips on!!! yay, i'm a happy camper again! thanks everyone!! you guys are the best! thanks for everything!
tuusinii
posted October 30, 2008 03:18 AM
Good that You got it figured out. Electric problems usually get solved only by hard work and it's the simple things that make in not to work!
flite leader
posted October 31, 2008 12:51 PM
ok 1st you stated the batt voltage was a problem
then you started in on current draw as a result of accessory devices
they are TWO different things !!!!
you addl current draw can be the result of improper wiring,
a bad ground or a bad accessory
yes it will bring the batt voltage down..................voltage alone is NOT indicative
you need to start isolating the HIGH Draw devices writing the current draw down
when engine is running...............THEN you need to take that circuit completely out of play
to Eliminate any other possibilties.
you may find the charging is OK with some devices with normal running
other devices NOT
if its down on ALL devices normal running no matter What........Then you have a charging or Batt problem
if it only down on 1 device/accessory ............the associated wiring or the device is your headache
good luck
bend your mind.....
2000redrocket
posted October 31, 2008 04:51 PM
if i may say if one device is drawing the running voltage down it could be the stator. believe me or not a bike with no accessories on it could seem to have a stator in good shape with running voltage in the upper 13s then turn on something small and it drops a lot. i worked on a honda that was charging but the stator was beet. put in a new one and he could run two extra 60w lights and still charge correctly.
those grips were probaly combined less than 40w. if your bike can not handle that (newer ones) something is up.
i am glad you got it. my c14 idles 14.2ish
0.23238205909729 seconds processing time
