BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Hindle System & Block-Offs Installed But........ NEW TOPIC NEW POLL POST REPLY
moodybluezx12r
posted August 30, 2002 11:04 AM
My bike is now back firing. Does anyone know what causes your bike to back fire? and also, will a powercommander help?
Raleigh, NC
Ride it! Like You Stole It!
  Ignore this member    Click here to visit moodybluezx12r's homepage.
posted August 30, 2002 11:08 AM
Which system? On or of the gas Back Firing? Any Ignition advance?
moodybluezx12r
posted August 30, 2002 12:57 PM
Stealth. Off gas. No timing advance.
Raleigh, NC
posted August 30, 2002 01:20 PM
Retarded will cause a Back Fire, Lean will also! I have no "Block Off Plates" and no back firing off of the gas! Only at the rev limiter! Advance 2.5 degrees (1/2 mark) on an advancer! If no advancer, No Techlusion, no Power Commander, the only thing left is to turn your TPS to about 1.150 DC Volts! It should stop the back fire, but will lose a few HP!
If you want the bike to run perfectly, It cost some money or have friends that will give you these things! With nothing to adjust, you have no way to adjust!
moodybluezx12r
posted August 30, 2002 03:35 PM
They say if you're going to do it do it right...ordered my powercommander from parts411 30 min. ago. I have a dynocenter located here in raleigh, nc. probaly will end up having them make me a custom map. Thanks again.
Raleigh, NC
posted August 30, 2002 05:04 PM
Do not be in the biggest hurry to get a "Custom map"!! First install the PC3R and then load a map close to what you need! Then take it to a Dynojet and had a print out made with the hp, Torque and A/F Ratio printed out in 1000 rpm intervals! Take the time to look at the map and make a few adjustments with the buttons and have the bike spun again and get a second print out! This is all you need to see! The buttons are 2% per bar adjustments, Go haome and make map adjustments then look at a cliff randall map to get great on off on response! Understand your system and learn! That is what I did and could not have a better running bike! I did not know all of this stuff to begin with I learned at the age of 58 by trial and error and a little time! So can you! Then you can map any bike you get and save a fortune over your life time! (Me, just a few dollars )
zx12rpilot
posted August 30, 2002 06:14 PM
Thanks Vince, great advice!
BA
posted August 30, 2002 09:04 PM
I guess you plugged up the small hose that used to go to the Kleen air valve?? What about the larger rubber hose that used to feed into the Kleen air?
posted August 31, 2002 05:27 AM
"NO" I hooked the system up to my Crank Case Vent!
BA
posted August 31, 2002 05:15 PM
not you man! Moody!
0.21936893463135 seconds processing time
