BIKELAND > FORUMS > ZX12R ZONE.com > Thread: spark plugs zx12r NEW TOPIC NEW POLL POST REPLY
slarpo909
posted September 26, 2008 02:15 PM
spark plugs zx12r
have a 2000 zx12r. could someone help explain the best way to change spark plugs.looks like it could be a pain in the a$$. any info would be helpful. thanks
harpo
Johnnycheese
posted September 26, 2008 07:07 PM
it is quicker if you pull the motor.
LOL
posted September 27, 2008 04:51 AM
use the factory tool!
NOX
PMRA / TMRC Super Street 4022
posted September 27, 2008 09:05 AM
It can be done.........., but not on a full stocker with all the stuff on it.
Mine is pretty stripped, none of that crap on the top of the motor, but I only change plugs once a year, at the first of the season........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
zx12dak
posted September 28, 2008 05:47 PM
Did them the other night in 2 hours, cleaned the air filters too in that time!!
tuusinii
posted September 28, 2008 08:18 PM
Yes! It really isin't as bad job as everybody says to You. It's little bit tight but You got the space You need to do it. And because of the frame You don't even need to remove the fuel tank as in "normal" bikes. So I find it even easier! Tight, yes, but hard, no.
Megabyte
posted September 29, 2008 02:41 PM
It is a PITA
posted October 03, 2008 06:02 PM
It's all in the factory tool. Oh yeah, and small hands,,,,,,
posted October 03, 2008 06:15 PM
getting rid of all the smog crap like Nox said helps big time too! save a headache and dont attempt it without the factory tool. and when you pull the stick coils out, angle them to the front of the bike
rgeorge
posted October 06, 2008 06:33 AM
On the right side of the bike, loosen the bracket that holds the fast idle cam so you can push the idle and throttle cables out of the way.
Ive changed the plugs a couple times without the tool. Just a 3/8 ratchet, sparkplug socket and a short extension. You have to drop the socket in the hole, then attach the extension then ratchet. The part that sucks is removing the socket. I used pliers and a long screwdriver to disconnect the extension, and pull out the socket without letting it fall back in the hole.
0.22899603843689 seconds processing time
