BIKELAND > FORUMS > ZX12R ZONE.com > Thread: How low is too low? NEW TOPIC NEW POLL POST REPLY
TireKiller
posted September 22, 2008 07:44 AM
How low is too low?
I had an 05 12R that I had the muzzy links on it. I had it set at the lowest setting in the rear and I had the front down to where the bottom of the lower clamps were just above where it starts to taper.. This worked fine except the front was a bit higher than the back unless I strapped it..
I now have an 03 12R with the same setup but I lowered the front a little more to where the bottom bolts/half of the lower clamp are right after the taper and the top bolts of the lower clamp are before the taper.. Basically I was wondering if thats enough clamping force just having the 2 top bolts of the lower clamps and the upper triple tree clamps holding it.. Its alot closer to level this way, I just want to know if its safe.. This is basically a track/drag bike only, but I do have to drive it about 5 miles to the track from the shop.
Thanks.
Chris
posted September 22, 2008 07:50 AM        Edited By: Shane661 on 22 Sep 2008 15:51
I don't think that is a good idea. I would slide the forks 1" up in the triples, and then pull it down with a strap. You can get right down to the ram air scoop with the strap; that's how I ran mine.
posted September 22, 2008 08:37 AM
What Shane said...
What your talking about is good if you cut your forks down, put the blocks in the fork tubes and take the front fender off !!!
TireKiller
posted September 23, 2008 07:51 AM
thanks for the help, I figured it wasn't a good idea..
shiphteey
posted September 26, 2008 04:48 PM
Don't do it. My 00 was lowered a little more than 1 inch....got home after running over 200 at Maxton...1 fork was 3 inches through, the other about 4. Do it right ;-)
Middle hole in the lowering link still has the bottom sometimes scraping the ramp, and I have a low with a ramp that lets lowered bikes up w/less scrape than most ramps I"ve seen.
A.
Gemini Motorcycles
TireKiller
posted September 29, 2008 04:53 PM
Gonna order the lowering blocks from snitchz er however you spell it..
Thanks for the info.
2000redrocket
posted September 30, 2008 12:34 PM
i did some mesuring and if you slide them up the 2" to match the rear i am going to get .020 brass shim stock and cut it a tad short from overlaping and it will make up the difference of the taper and the softer brass will grip those machineing lines . it will hold but i am thinking the front fender will need to go bybye.
TireKiller
posted October 01, 2008 04:17 PM
I was thinking of making the blocks like the ones schnitz sells, does anyone know the diameter of the pipe?? and the length??
0.24557900428772 seconds processing time
