BIKELAND > FORUMS > ZX12R ZONE.com > Thread: HELP!!! PLEASE TELL ME IT'S NOT TRUE! NEW TOPIC NEW POLL POST REPLY
NotAnotherBike
posted August 26, 2002 05:58 PM
Just picked up my new ZX12 Saturday. Rode it 60 miles, and when I stopped, all I smelt was burning rubber. Looked at the radiator overfill - nothing! Checked it cold - nothing! Did they forget to fill it when they serviced it??? Temp gauge was pretty high, but not showing in the red. ANY IDEAS???
your car is slow
Fuck Nitrous...Got Boost?
posted August 26, 2002 06:07 PM
Probably just put some in...just not enough. If you had no coolant you wouldnt have lasted 60 miles
Do not taunt happy fun ball!
NotAnotherBike
posted August 26, 2002 06:11 PM
What could the burning rubber smell be? hot hoses?
jason370
posted August 26, 2002 06:14 PM
i had a odd smell at first, i figured that it was some sort of protective spray or cleaner or something. sure enough it either burned off or went away.
jason
  Ignore this member    Click here to send jason370 an AIM message.
your car is slow
posted August 26, 2002 06:16 PM
Id assume it was the new packing in the pipe burning off.
I smelled the same thing when i got mine....just more pronounced near the exhaust.
ZHooligan
Post Whore Extraordinaire!
posted August 26, 2002 06:24 PM
Probably not a big deal. Take the time to see how much water you have to put in the radiator to top it off. Likely less then a half of a cup. If so no big deal at all.
If the bike is really low on water or none at all the temp gauge will not read hot as it has nothing to actually read! But most likely you just selled the pieces burning in. Especially if the dealer didn't run the bike much if any prior to giving it to you.
future; -- Youth is forever.
NotAnotherBike
posted August 26, 2002 06:25 PM
Thanks! Now maybe I can sleep! I thought I just toasted a brand new bike...
Wildman
I only look confused
posted August 26, 2002 07:36 PM
Well, mine smelled pretty bad the first day I had it too. Most of them do, but.......
I know of one ZX12 (Wrenis's bike) that had the fairing mounted a little too far to the left and it was being burned by the exhaust.
When we figured out what was happening, we loosened the mounting bolts and pushed it over then re-tightned it. All better now.
If you build something Idiot Proof, The world will build a better Idiot.
notanotherbike
posted August 28, 2002 05:50 AM
It took about a cup and a half of water to fill it up. The dealer said they come from the factory filled, but must not have been enough. They also said the smell is from the packing in the muffler. Rode it last night & seems fine. Keeping the proverbial fingers crossed. Now I just have to wait those damn 1000 miles before I can see what this puppy can do!!!
Red 12R Rocket
posted August 28, 2002 06:05 AM
What packing?? Is it an aftermarket exhaust? The stock muffler doesn't have any packing!
notanotherbike
posted August 28, 2002 06:35 AM
It has the stock exhaust - the dealer said there is some packing in it. I thought it only had metal baffles... It's got 100 miles on it now & the rubber smell is almost gone. Maybe there's just some sealant in the canister that needs to cure?
beaulauber
Green Blood
posted August 28, 2002 06:46 AM
Damn...!!!! what a coincadence(sp). Evertime i get on my bike i smell burning rubber Glad you got it figured out...
your car is slow
posted August 28, 2002 07:14 AM
Really? damn..learn somethin new every day. now I wonder what that smell was :/
beansbaxter
posted August 28, 2002 07:22 AM
The temp guage will read high at first, but the longer you ride, the better it will be. Get that first 3000 miles on it quick, and you wont have the temp problem ever again.
madmike
posted August 28, 2002 10:11 AM        Edited By: madmike on 28 Aug 2002 11:13
Was there white smoke bellowing near the back of the bike with that rubber smell that seems to be my problem and I cant quite figure it out either, hmmmm..... I wonder what it could be???
Mad Mike
notanotherbike
posted August 29, 2002 12:23 PM
YEAH! THAT'S WHAT IT LOOKED LIKE!!!
harryzx-12
posted August 29, 2002 12:59 PM
I have that problem too
ridgeracer
posted September 01, 2002 09:54 AM
I had the same problem just after my first rear tire wore out.
I tried to look over my shoulder to see where it was coming from but when I did the back end would swing around...
ZHooligan
posted September 01, 2002 03:12 PM
These are the same guys bitching about replacing tires. Those damn Dunlops just don't last. It is a wild guess, but.... I'll bet you guys didn't vote for Nader either.
OZZY
need guberment cheese
posted September 01, 2002 04:11 PM
Take a stock canister and cut it apart, it has packing in it! It is a double wall construction and has a fiber type packing. Also the mid pipe has the same construction.
"It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and we're wearing sunglasses......HIT IT!"
Blues Bros.
ridgeracer
posted September 01, 2002 08:32 PM
How much you want to bet? Not only did I vote for Nader I was the 'Vice Facilitator' of my county's Green Party.
Just something about green....be it motorcycles or political organizations....
ZHooligan
posted September 01, 2002 08:53 PM        Edited By: ZHooligan on 1 Sep 2002 21:53
Now that's what I call being loyal to green!!
posted September 02, 2002 12:31 AM
The reason your bike is running *hot* is because there is air trapped in the cooling system. Air expands greatly when heated and the expansion of the rubber is probably what you smell.
Just add distilled water only for now. THe factory coolant mixture is much to rich for my tastes. I think they mix it about 50/50. Your better off going with 60/40 mix. 60% water and 40% antifreeze.
You are probably also smelling the catalytic converter. Pull your stock muffler off and chisel that stuff out of there! Instant 5hp+ at redline.
So the 2002 models now have only a 1000 mile breakin? Cool!!
madmike
posted September 03, 2002 06:16 AM
Zhooligan, have you ever heard me bitch about my tires not lasting? Im damn glad the M/T 2 that I use last as long as it does!!
Mad Mike
who the hell is nader... LOL..
BIKELAND > FORUMS > ZX12R ZONE.com > Thread: HELP!!! PLEASE TELL ME IT\'S NOT TRUE! NEW TOPIC NEW POLL POST REPLY
0.29357004165649 seconds processing time
