BIKELAND > FORUMS > ZX12R ZONE.com > Thread: codes NEW TOPIC NEW POLL POST REPLY
zx12r rider
posted September 10, 2008 02:21 PM
codes
i was wondering if anybody can tell me how to check codes i would greatly appreciate it, my battery died ,so i got a new on ,charged it like they said and installed ,now the bike wont start , it cranks but wont start ,i even tried to push start it ,so any help you can give would be great thanks.
posted September 10, 2008 02:34 PM
is the fi light on?(only reason to check codes) if not, its probly just flooded. once they flood, its a real pain to get them started. probly have to pull at least 2 plugs and dry it out. if you have a fault code: the yellow wire to nowhere by your ecu. ground it out for more than 2 seconds and keep it grounded. look at the fi light and read the long and short bursts. the message just keeps repeating as long as you ground it. a long flash and a short flash is fault code 11. 1 long and 5 short = 15, 3 long, 6 short, 36 ect ect
zx12r rider
posted September 10, 2008 03:38 PM
the fi light isnt on till the second time of cranking then it flashes
shiggsy
posted September 11, 2008 04:37 AM        Edited By: shiggsy on 11 Sep 2008 05:38
http://www.bikeland.org/board/viewthread.php?FID=1&TID=41206
zx12r rider
posted September 13, 2008 05:53 AM        Edited By: zx12r rider on 13 Sep 2008 06:54
thanks shiggsy , i took off the inspection covers and poured gas in each throttle body and it started then died so for some reason im not getting fuel . is there a hidden fuse or something that im missing i checked the ones under the gas tank cover . is there one for the injectors somewhere, thanks for all the help
shiggsy
posted September 13, 2008 08:17 AM        Edited By: shiggsy on 13 Sep 2008 09:17
No fuses for the injectors, just a connection block between them and the ECU. When you switch on can you hear the fuel pump priming ?
zx12r rider
posted September 13, 2008 09:02 AM
i found my problem the i unhooked the power commander and it fired right and ran , now i have get the usb cord to see if the power commander lost everything when it lost power or if its fried i found the wire that goes to the batery had a bare spot and must have shorted out hopefully its still good,thanks again for the help
0.22061610221863 seconds processing time
