BIKELAND > FORUMS > ZX12R ZONE.com > Thread: False neutrals, is it me? NEW TOPIC NEW POLL POST REPLY
iflyguns
posted August 24, 2002 03:44 AM
Hey all!
I continue to get many false neutrals everytime I ride mostly between 5th and 6th. I can actually concentrate on the shift for positive engagment and it will still do it, not every time but a lot! I have tried oil from Klotz to Motul all in 10w40 and it still does it. I can feel a little click or notch when shifting into 6th. Anyone else? I have also adjusted the shift lever, no help though.
Tony D
Tony D
Ballisticzx12r
& Deals Gap Board Member
posted August 24, 2002 04:46 AM
Sorry I never had any problems not on either one the 2000 or 2002. I think Otis had said something about it.
Bart
Be fast and Be safe
  Ignore this member    Click here to visit BallisticZX12R's homepage.
TedG
posted August 24, 2002 09:19 AM        Edited By: TedG on 24 Aug 2002 10:20
It is you, you need to adjust the shifter down alot and the problem will go away. Even though you adjusted it you still need to go more. Believe me, dozens here have taken my advice with this and it works.
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
iflyguns
posted August 24, 2002 10:07 AM
I do beleive you Ted and will try it! Why only on the fifth to sixth shift?
Tony D
TedG
posted August 24, 2002 07:40 PM
It could be that things between 5th and 6th take a bit more efort.
Ted
The fast color!!
Green 2005 ZX10R
ZHooligan
Post Whore Extraordinaire!
posted August 24, 2002 10:27 PM
I have been pretty lucky I guess. No false neutral issues on my 00. My complaint is finding neutral! Easy to do at a stop, but not while rolling up to a stop!
future; -- Youth is forever.
ra12r
posted August 25, 2002 04:51 AM
ZZZZ, the neutral issue is dependant on oil pressure. The "positive neutral finder" works with some little steel balls that are pushed into place by the oil pressure. This system creates a situation that you cannot go into second gear while the engine is not running and you cannot go into neutral while moving too fast. It works well.
0.24436497688293 seconds processing time
