BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Right turn no lights!!!! NEW TOPIC NEW POLL POST REPLY
chango
posted August 18, 2008 01:33 PM
I'm tuning right to get into my drive way and I cut it a little sharp and then my lights blink!!! So I'm thinking to myself " I didn't just see that". So I turn the handle bars and give it a rev and the lights go out again. I then turn left and no problem. So I look at all of my wires and I don't see any frayed or twisted wires. Anyone else ever had this issue? if so where do I start? I cannot see where any wire issues at the moment. thanks in advance.
Dane
posted August 18, 2008 05:16 PM        Edited By: Dane on 18 Aug 2008 18:16
Chango, my .02 ,I would check the plug on the LH handlebar switch. Nothing in the harness ( I Think) moves when riding except the handle bar switch harnesses. Disconnect and make sure the pins are in the plugs tight, both male and female sides. If all good there, take the screws out of the switch and make sure the solder connections are good. Other than that I got nothin' .
chango
posted August 18, 2008 05:39 PM
Thanks Dane!
I will givfe it a look at first day light before I go to work in the morning! You know the switch makes perfect since because when I first got the bike I took used pullties to hold the wires becuase they kept coming out of the factory wire restraints. I'll let you know. I really apprecieate the help!
Dane
posted August 20, 2008 04:45 AM        Edited By: Dane on 20 Aug 2008 05:46
Chango, give us a report.........inquring minds want to know
chango
posted August 20, 2008 10:29 PM
Took a look at the switch and it looks to be in good shape. I just removed the pull tie I used to secure the wires and it did not seem to do it anymore. My timing has been pretty bad I've only been around my bike in the broad day light. So I'm going to have to wait until friday (when I will have ride time) to find out if that was the issue. I will post as soon as I get a conclusive look at the results.
0.27508902549744 seconds processing time
