BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Counter Balancer Question ** Keep it or ditch it?** NEW TOPIC NEW POLL POST REPLY
DJ_JONES
Turbo or NOS? Pick your poison
posted June 30, 2008 04:52 AM
Been trying to decide if I should keep or remove the counter balancer in my motor. Whats the skinny on this? Pro and Cons?
I have already had the internals (crank, rod, pistons) balanced by a machine shop.
My machine shop guy says keep the counter balancer for high RPM safety I am just not so sure. Lemme know.
DJ JONES
Humble, TX
2000 ZX-12R (1290 + Wet kit)
2004 Hayabusa (Stage 1 Turbo)
Texas Shootout #1762 & #777
MDB Racing (HERE WE COME)
  Ignore this member    Click here to visit DJ_JONES's homepage.
woppi
posted June 30, 2008 05:28 AM
for street ridig -- keep it
for drag racing --- kill him !!
talk with entropy -- he is the man - who knows more !!!!!!!!!!!!!!!!!!!!!!!!
woppi
1st TFA Member / Austria !
2000 Limited ZX12R NOS
DJ_JONES
posted June 30, 2008 06:05 AM
Come on Karl..... give up the info....
DJ JONES
Humble, TX
posted June 30, 2008 07:27 AM
Karl is busy in Maxton, but ill try to help. we got rid of the balancer on my bike and dads. its supposed to give about 2-3 hp by taking out rotating weight and decreasing oil windage. since it doesnt affect primary balance of the crank, it wont unbalance the crank if you take it off. its Not like a harmonic damper on a v8.
one thing i was convinced to do afterwards however was to add the 2 extra oil squirters in the case. some guys say thats not a required thing as theres enough oil from windage getting to the pistons. BUT we just cut down on windage by taking out the damper.
extra oil to cool the pistons on your 1290 nitrous bike is a good thing! not less!
you can run the muzzy dummy shaft (easy) or take the damper off of the stock shaft and weld the holes shut.
posted June 30, 2008 07:37 AM
a pic is worth a thousand words
do you want to just spray 2 pistons with cooling oil or all 4?
johnnycheese
posted June 30, 2008 02:34 PM
kill it period
zrexpilot
posted June 30, 2008 06:19 PM
keep it
DJ_JONES
posted June 30, 2008 06:58 PM        Edited By: DJ_JONES on 30 Jun 2008 20:13
Hmmmmmmmmmmmmmmmm
Now it is clear as mud
As far as the picture goes.... if I remove the counter balancer and install the Muzzy Counter Balancer Removal Shaft are you saying only 2 pistons will get oil?
Really.... I dont know. This one is new for me but seeing that I am pretty mcuh building a grudge bike I figured I would toss anything I didnt really need.
DJ JONES
Humble, TX
posted June 30, 2008 07:36 PM
Builder and tuner of the fastest N.A.Hayabusa and ZX12 in Texas says "kill it"
there are only two oil squirters in the bike stock.(only sprays two pistons, 2 and 4) it looks like they ment to put four, but just didnt drill and tap for the other two. so on my bike and dads bike i ordered the squirters from kawi (only a few $) and basically "finished" the upper case by drilling and tapping for the other squirters. the brake clean action shot shows a factory installed squirter and one i put in spraying 3 and 4
zrexpilot
posted June 30, 2008 07:40 PM        Edited By: zrexpilot on 30 Jun 2008 20:44
crank weight helps bogging off the line and theres less rpm drop between gear splits. Keep it. In my opinion
Light cranks are for road racing,
The car guys have always added weight to the crank for drag racing
posted June 30, 2008 07:49 PM
not to start an argument (trying to promote friendly discussion) but how does added crank weight help the rpm not drop between gear splits(im assuming that means up shifts) wouldnt it drop a set amount regardless of weight as its not an automatic?
i understand the holeshot thing, but i believe that can be compensated for by higher rpm.
in my opinion
zrexpilot
posted June 30, 2008 08:09 PM
Inertia and momentum. objects in motion tend to stay in motion.
member ? you member LOL.
posted June 30, 2008 08:32 PM
yeah, i had honours in physics actually....
but we dont have an automatic, and when we up shift gears, the rpm has to drop by a set amount or you get clutch slip. once it drops, it has to climb again, and a lighter rotating assembly will allow that to happen quicker
how many car guys that drag race have a standard tranny? very few around my area...
zrexpilot
posted June 30, 2008 08:59 PM        Edited By: zrexpilot on 30 Jun 2008 22:01
. Its a bog when you up shift , thats why rpm's drop. heavier rotating mass bogs less. the taller gear puts a load on the engine and slows its rotation.
posted July 01, 2008 04:38 AM
junk it
the same angular momentum which minutely resists dropping rpm, minutely resists gaining rpm. Since you are gaining more than you are dropping as you go thru the gears, i say junk it.
That sdaid, i don't think it makes much difference either way, but it does save a couple pounds,...
DJ_JONES
posted July 01, 2008 07:07 AM
And we all know that TFA needs as many pounds dropped as we can get!
DJ JONES
Humble, TX
posted July 01, 2008 08:37 AM
counter balancer: "you don't have to diet to like it!"
zrexpilot
posted July 01, 2008 01:53 PM
What do you guys think the counter balancer does ?
It does one thing, it counter reacts the torsional twist of the crank shaft.
Mains can suffer from this.
The cases arent strong enough to prevent this. Its there for a very good reason.
johnnycheese
posted July 01, 2008 02:18 PM
Nope that is an incorrect statement
zrexpilot
posted July 01, 2008 02:43 PM
Ok Mr I smoked more zx12 bearing than you can count.
Explain it to me .
posted July 01, 2008 05:12 PM
i thought it was there so the bars wouldnt vibrate as bad when you are cruising down the road....
DJ_JONES
posted July 02, 2008 03:38 PM        Edited By: DJ_JONES on 2 Jul 2008 16:39
:Corn
BTW.... mine vibrated the bars with it in there anyways.
DJ JONES
Humble, TX
johnnycheese
posted July 02, 2008 04:45 PM
and we have a winner
rgeorge
posted July 02, 2008 05:13 PM        Edited By: rgeorge on 2 Jul 2008 18:16
I agree its in there for a reason, but it has nothing to do with crankshaft twist or strength of the cases.
It is there to counteract the second order harmonics of the pistons. The engine has inherent first order balance because of the opposing motion of the pistons. Since the piston motion is not perfectly sinusoidal, the difference in piston accelerations create a second order vibration at twice the crankshaft speed. The balancer is designed to oppose this.
http://www.epi-eng.com/piston_engine_technology/piston_velocity_and_acceleration.htm
http://en.wikipedia.org/wiki/Balance_shaft
posted July 02, 2008 08:56 PM
rgeorge is correct. It has nothing to do with torsionals. Take it out, block the oil. Do not add additional squirts. Removal reduces rotating mass, basic weight, frictional loss and windage. People used to ask me what my ZX-11 felt like with the balancer out- my response- "It feels like a Suzuki".
0.22455501556396 seconds processing time
