BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Regular Gas? High test? Ethenol? NEW TOPIC NEW POLL POST REPLY
H2 to ZX12
two stroke power
posted June 15, 2008 05:31 PM
I've read in here that several of you run regular gas in your 12R. The first time I did it, the engine ping/knocked pulling away from a traffic light. I immediately topped off my tank with premium and drove easy till I used up that tank.
I was having a conversation with my local gas station owner, who is a mechanic.
He felt that ethenol was harmful to engines, reduced gas mileage, and hurt performance. It made me wonder if the regular gas that I tried in my 12R had ethenol in it.
comments? thought? Regular? Premium? Premium is $4.20 here now
  Ignore this member    Click here to visit H2 to ZX12's homepage.
psycho1122
posted June 16, 2008 06:00 AM
Another reason to have your 12R mapped.
I have mine mapped with 91 pump in the tank. Weather it's oxygenated or not, I will get the correct A/F out the pipe.
2000redrocket
posted June 16, 2008 12:14 PM
i used 89 in my bike like some did with no issues. now i have a advancer on now so i use high test now. before it worked ok on 89. just be carefull.
2000redrocket
posted June 16, 2008 03:00 PM
if you canset your bike up for E85 i think it is rated at 105 octane i think.
tshultz
posted June 16, 2008 03:36 PM
I have put 87 in my bike when it was empty for drag racing no knocking or pinging.
But for street riding I always used 90.
posted June 16, 2008 06:12 PM
took dads bike for the first test run tonight. 87 octane and advanced 3 degrees.i have been told 4 degrees is ok on 87....
posted June 16, 2008 09:45 PM
When you cut back on the octane you are removeing safety factor. What works at night might scuff a piston on a hot afternoon. On a stock bike it's probably OK, but on anything with advanced timing or more compression or sustained high speed in high outside air temps I wouldn't do it. Just not worth the chance.
H2 to ZX12
two stroke power
posted June 17, 2008 03:07 AM
thanks all, the only mods to my bike are an arata pipe and a pc3 with a map for the arata.
It runs fairly rich. The temp outside, when it pinged was in the high 80's - low 90's.
posted June 17, 2008 02:25 PM
im in canada... might have something to do with it
dads bike is stock internals besides the head clean up and muzzy dummy shaft
0.28314399719238 seconds processing time
