BIKELAND > FORUMS > ZX12R ZONE.com > Thread: oil moving up stator wires? NEW TOPIC NEW POLL POST REPLY
h2smokin
posted August 07, 2002 06:00 PM
just noticed post over on another board. anyone here having this problem? mine is full of oil up at the connectors as well as being all over the side of toolbox. anybody know of any fixes coming from kawasaki yet? bike is sidelined for now til remedied. thanks for any info
Diverig
posted August 07, 2002 07:27 PM        Edited By: Diverig on 7 Aug 2002 20:30
Just talked to my dealer and sofar nothing.
I fixed mine with some miner surgery to the wiring loom.
Step 1 unhook the plug in the tail.
Step 2 Remove the stater cover and remove the wiring harnes.
Step 3 use electronics cleaner to clean out the oil from the harnes
by cutting a SMALL slit in the 90 degree boot and using the straw
to inject the cleaner into the harnes make shure to get all the oil out
Step 4 use a good grade silacone (sp?) I used black permatex.
Step 5 inject silacone into the slit and fill as mutch of the harnes as you can with it.
Step 6 reasemble the stator wiring and cover.
Step 7 This is the hardest part let the bike sit OVERNIGHT atleast 24 houres
this has semed to have fix my leak.
BigJ12
posted August 07, 2002 08:22 PM
The only problem with that is that it was found out that the oil is actualy making it's way up inside the individual wire insulators and not the loom. Therefore you would have to seal each wire where the insulation ends and the bare wire begins inside the stator to make the seal job complete.
I was a little sceptical about the oil getting up to the tail section that way but it seems to be true. At least I know to look close at all the possible ways oil can make it's way up to the connectors. Mine is not leaking but I will have to do some serious looking into this and see if I can prevent it from happening.
BigJ12
"Blessed mother of acceleration, don't fail me now"
Nebraska12R
posted August 07, 2002 08:55 PM
There should be no oil at your stator anyways, there is a bearing failure at the root of the problem. Your stator should be OIL FREE.
Diverig
posted August 07, 2002 09:13 PM
That was one of my questions to the dealer about the oil in the stator.
The dealer told me that it was fine the oil is free to move in and out of the stator.
Nebraska12R
posted August 08, 2002 01:17 AM
I don't understand why it would be able to move around in there? Everything in the stator area is electrical and should be protected from liquid, let alone hot liquid like the oil in the engine.
Ninjaman12R
as a Deal's Gap tour guide.
posted August 08, 2002 06:15 AM
I hate this shit......
My bike is doing the same thing. I've already did the silicone thing and it seemed to work for a couple of rides, but now it's leaking everytime I ride the bike. I hate oil leaks, and this one has got me pissed. I'm gonna tear back into the bike ASAP and try another approach. The problem is that I don't really know what else I can do. I'll figure something out I guess.
Either way I think this should be a recall issue for sure. Somebody could go down as a result of this. If I didn't have a hugger, there is no doubt in my mind that I'd be oiling down the left side of me rear tire. I'm sure some of the oil has made its' way to the tire already. Not a good thing at all.
ra12r
posted August 08, 2002 06:36 AM
Nebraska, you are not correct. There will be oil in that area, that is why the stator cover has a gasket. The outside bearing is not a gastet. Ninja, did you find oil in the loom? Big, was your loom dry?
BigJ12
posted August 08, 2002 09:00 AM
I have no oil at all......yet! but I thought it was traveling up the loom, now I'm being told that the oil is not traveling up the loom but up the individual wires between the insulation (Jacket) and the actual copper wire!
This may be why Ninjaman is leaking again? he sealed the loom and not the individual wires.
BigJ12
Ninjaman12R
posted August 08, 2002 12:31 PM
Yeah...
It very well could be that it is traveling up each individual wire. That fucking sucks.........., all I can say is that I'll work at getting it fixed.
harpoon
Hired Gun
posted August 08, 2002 07:49 PM
Harpoon here, I've had the same problem. You can call me and I'll tell you how I fixed the problem. I live in Georgia so don't call me at 2 in the morning. 770-924-8579 Ask for Scott
Do you feel lucky?
Nebraska12R
posted August 08, 2002 09:47 PM
I stand corrected, when I got home from work I looked at my service manual and saw that. Sorry for the mis-info
Ninjaman12R
posted August 10, 2002 09:10 AM
tried to....
harpoon,
I tried to call you a little while ago but got your machine. I'll try and catch you sometime monday.
Ninjaman12R
posted August 12, 2002 03:58 AM
top
bump
ZX12eR
posted August 12, 2002 06:36 PM
Can I call too? Can I call too?
Scott, I've got this problem bigtime and want to take a 1500 mile trip Friday? Can I call too? thanks!
ZX12eR
Ninjaman12R
posted August 13, 2002 03:57 AM
top
up
Ninjaman12R
posted August 16, 2002 04:08 AM
HEY HARPOON !!!!!
I'm gonna try to contact you again this weekend. Hope I catch you and find out you "fix".
0.24668598175049 seconds processing time
