BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Clutch problems NEW TOPIC NEW POLL POST REPLY
dwb
posted August 07, 2002 05:11 PM
Clutch problems
I just installed the muzzy clutch kit and I have a problem.
The clutch does'nt disengage so if I put it in nuetral and start it then pull the clutch in and put it in first it jumps forward and dies.
I have taken it apart and put it back together 3 times now and followed the instructions to the letter.
Any suggestions would be helpful .
thanx,
Patrick
canadians put DOOTIE on everything...
zxlnt
posted August 07, 2002 06:27 PM
Check the slack in the cable if U have too much it wont disengage the clutch fully. Also what did ur stack height measue before you put the clutch pack back in?
ra12r
posted August 08, 2002 06:47 AM
You put a full size fiber on the inside against the chatter spring. I would suggest just removing the "chatter spring" all together!
madmike
posted August 08, 2002 07:11 AM
dude I never even thought of that!, bam you probably hit that one on the head!
MM
You did I just called him and sure enough that middle spring is in there.
RAC4IT
Bergie
posted August 08, 2002 09:00 AM
Mine was shattering the smaller innermost fiber on a regular basis so I pulled the rings and used a fullsize fiber- no problems.
dwb
posted August 08, 2002 08:26 PM
ra12r
You were right ,got it back together ,been ridin it all night,gonna take it to the track tommorow.
thanx for the help fellas
0.28063988685608 seconds processing time
