BIKELAND > FORUMS > ZX12R ZONE.com > Thread: installing the stepped tube race Hindle pipe NEW TOPIC NEW POLL POST REPLY
johnnnyboy
08 Concours 14
posted May 19, 2008 03:00 PM
should i leave the gaskets between the head pipe and motor ? and I just use high temp silicone for all the joints to right ? what else in general besides the map to I need to adjust / change after I put the pipe on.
thanks
posted May 19, 2008 11:02 PM
absolutely use the copper O gaskets, but i would NOT use any silicone on the joints if you ever might want to separate those pieces in the future.
posted May 20, 2008 06:19 AM        Edited By: VincentHill on 20 May 2008 07:22
The Gaskets Yes! It is for Debate on the HiTemp Silicone! I have used it with no real problem (Just make sure no one is behid the bike when you start it up because that Silicone comes out at a Very High temp and will burn the Hell0 out of you! Do not ask).
I also used Silver Antiseize and I think I like that Better! Either way I was able to get the Pipes apart and had a good seal! Just make sure when you are finished installing everything that you take a double paper towel and spray Brake clean on it cna clean all of your finger prints off the pipe BEFORE Stating it! Otherwise it will leave a Nasty stain!
Also after starting and heating the pipe you can take WD40 or CRC556 and clean the entire system and yes it will smoke for a minute but the residue will keep everything off the pipe! Specially with a Ti Muffler! To me, the PIPE Design cannot be beat! Most Battle Ships have welding as good but it is not the Beauty it is the ------
I forgot to add, since you have a 2000 I have several Maps with a stock Fuel Pump and the Muzzy Pump and the map I used to make 183 HP and get 40 MPG I will send you if you send me a PM with your e-mail address
0.26928901672363 seconds processing time
