kawdawg
posted August 05, 2002 01:25 PM
Muzzy clutch burnt after 500 Miles
Couple of weeks ago I put a Muzzy clutch kit in my 2000 12 that included the new inner hub. Put around 500 miles on it if that. A buddy and I deceied to go and run them in the 1/4 mile at a local track. The day before I go down the road from my house to a 1/2 mile straight away to practice my holeshots. I do this 5 times. I slipped the clutch a little but I didn't slip it too much. I still had the front in coming off the groung everytime I pulled out. So I couldn't have slipped it too much. After my 5th attempt I shift from 1st to 2nd and the rpm's shoot straight up. I know I was fucked. I think maybe they were a little overheated. I turn around and pull over and tried to pull out and nothing. The cluch was gone. I had to push the bike about 3'4 of a mile before I got help. So I go home and get my trailer and pick my bike up. Tear the clutch apart and the plates are BLACK. Fried worse than my stock plates that I got 5000 miles out of. I call Muzzy and talked to them and no matter what I said I was wrong. What did I do or maybe I got some defective clutches. Would it have anything to do with the thicker metal plates. I didn't ride the bike any differently with the Muzzy clutch kit than what I did with the stock clutches. And they were installed right also. Bit of advice please.
madmike
posted August 05, 2002 03:34 PM
to many things contribute to burnt clutch's, but definatly the nail in the coffin were 5 dragracing launch's in a row! man that will smoke a 12 clutch in a heart beat! you should not even to a dry hop. so you doing the 5 in a row. finished it off. couple of other questions? for ya do you wheelie, leave hard from stoplight's, do hard burnout's. did you have any play in your clutch lever?
MM
ZHooligan
Post Whore Extraordinaire!
posted August 05, 2002 04:06 PM
I would also question the five back to back practice launches. Especially if they were seriously hard launches. Everyone seems to forget we are talking some serious horsepower here. The World Superbikes and AMA Superbikes sometimes fry their clutches in a single launch or especially in the event of a restart. That is why often times in the event of a red flag they will install a new clutch to get a good start and enable them to finish.
Pretty much the message on this board and others have all warned about giving the clutch time to cool, the right hand lean to slosh some oil onto the clutch etc. I have followed the above advice with my Muzzy Clutch set up and I have zero problems and I have probably over thirty drag strip launches besides the everyday riding stuff as well as hours and hours on the race track.
future; -- Youth is forever.
zxlnt
posted August 05, 2002 04:07 PM
Don't hot lap it and make sure u give it time to cool down. U if dont let it cool down you can kiss it goodbye very quickly..
posted August 05, 2002 04:56 PM
did you offset the outer fiber by any chance?
Alao, like MM said, what about the clutch adj on the L bar, was there a little bit of slack??
kawdawg
posted August 05, 2002 05:20 PM
GUESS i DIDN'T GIVE THEM TIME TO COOL DOWN. hOW LONG BETWEEN RUNS TO LET THEM CIIOL DOWN. tHANKS gUYS
posted August 05, 2002 05:37 PM
What kind of oil are you using? Synthetics will add alittle more life over conventional oils.
A cheap and easy way to get some more oil flow to the clutches is to "flat spot" the puller shaft. Its the little shaft that connects to the clutch cover that pulls the clutch pack away from the basket. The side the goes into the engine (hollow shaft) is where the oil comes from. Flatspotting the round shaft .0200 or so will let just enough oil through to increase cooling.
Heat is the clutch's worst enemy!
mrfast
posted August 05, 2002 07:24 PM
I have 9000 miles on my stock clutch with 5 days at the strip,always about an hour between passes,no dry hops,I also weigh 225 suited,not a single problem!Last weekend I let a friend run it on an all bike day,he weighs 150lbs.I show up at the track late and he has already made 11 passes in about 3 hours.I used to run a mid 7 sec Suzuki and never saw so many burnt/warped steel plates!There were only 3 good steels left!He said he had a blast though!!My best 9.90,his 9.61.
kawachan
posted August 05, 2002 07:49 PM
I made over a hundred passes (nineteen in one night in less than four hours) before my clutch gave up the ghost.
Main thing for me was leaning it over and flooding the clutch with oil. I also run 3 and a half quarts of oil instead of three quarts like most of the guys do. Besides that, I usually run up and down the return road a few times to get the temp down on the bike between runs. Taking the oil fill cap off might not be a bad idea. Leaving the clutch pulled in between runs helps it to cool faster, too.
If you slip the heck out of it, you can fry a clutch in two passes EASY. I found that out when I ler my Busa-riding buddy try the 12 out one night.
Let it cool down between passes and mod the puller shaft a lil bit. Should do the trick for you.
RED NINJAS RULE!!
ninjamissile
posted August 06, 2002 04:19 AM
I have had more clutches than I care to mention including 3 Muzzy's. What I have learnt I have printed below I hope it helps.
1.Never hot lap (sure way to fry a clutch)
2.Always allow 25 minutes between passes.
3.No dry hops
4.Dont go mad with the burn-out especially with road tires.
5.Before each pass tip the bike over to the clutch side and squeeze the clutch lever a few times (allows more oil in and cools it down sum)
Ninja Missile
ra12r
posted August 06, 2002 05:50 AM
Ditto::::::::::: Did you offset your outer fiber?! How tight did you have your clutch cable?! Do you drag race much?! How do you have your stack arranged?! I couldn't just put the muzzy 10 steels in because it had my stack too low or pressure plate too close to bottoming out, so i added a 1.6 next to a 2.0 (2 steels) to get the right height.
psycho1122
posted August 06, 2002 07:40 AM
You are definately better off getting more oil to the clutch......Flat spotting the what is described in the Kawi Manual as the "Pusher Shaft" is a shade tree method. To have the hollow shaft cross drilled is more effective. If you have it EDM cross drilled .040, you will get a nice efficient dual "Spray" of oil inside the Hub. This dramatically improves the cooling of the clutch assm.
BA
posted August 06, 2002 10:40 AM
so, about that stack height!
when measuring, do I count the outside fiber pads in that measurement I s'pose?
ie. ensure the caliper's tang things are resting on a fiber pad, not the 'plate' piece?
boy I sure hope that made sense........
ra12r
posted August 06, 2002 10:56 AM
I believe you can do this better by "sight",,,,,the object is to give enough distance so the pressure plate doesn't bottom out on the hub....ie: full pressure is always present! It required me adding a 1.6 steel. I also changed the length of time i slip the clutch and the rpms i launch at....this is very subjective!!! You have to get a "feel" to launch.......
RAC4IT
Bergie
posted August 06, 2002 11:22 AM
Did you make sure you had 2~3 mm of play in the clutch lever before every pass? If you don't have free play in the cable; you'll smoke a clutch no matter how new it is! Check this by pushing the lever on the cover in by hand and making sure it wiggles freely before each pass!!
BA
posted August 06, 2002 11:40 AM
Good point Bergie. I now check mine on EVERY pass, and even toy with it between rounds by flicking the lever and getting that sweet 1/8" or so of gap at the edge of the lever. (a tip from Muzzy's)
My friend's on a 9R and he hasn't adjusted his TWICE and has screwed up good sets of clutches!
posted August 06, 2002 01:46 PM
quote: Good point Bergie. I now check mine on EVERY pass, and even toy with it between rounds by flicking the lever and getting that sweet 1/8" or so of gap at the edge of the lever. (a tip from Muzzy's)
me too, and I sure learned the hard way!
RAC4IT
Bergie
posted August 06, 2002 02:56 PM
Yup like BA and Entropy said I always reach down and nudge the lever at the clutch cover this way to avoid any 'misreadings' in the cable itself or the handlebar lever. It should move at least 2 mm to ensure that your clutch stack is fully seated. If there is any tension on the cable (indicated by the LACK of play or slack at the lever) then your clutch pack isn't fully seated and will slip and if it slips you'll smoke it even if it's new.. so learn to check it every pass!
