BIKELAND > FORUMS > ZX12R ZONE.com > Thread: engine removal/tilt NEW TOPIC NEW POLL POST REPLY
kaw12
posted March 29, 2008 01:37 PM        Edited By: kaw12 on 29 Mar 2008 17:32
engine removal/tilt
engine removal?
NOX
PMRA / TMRC Super Street 4022
posted March 29, 2008 01:57 PM
let the throttle bodies loose, and the top rear engine bolt.......
Just as easy to totally remove the motor at that point.....
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
kaw12
posted March 29, 2008 02:04 PM        Edited By: kaw12 on 29 Mar 2008 17:33
ok
starchild
posted March 30, 2008 08:13 AM
hey guys never used this method but it sounds solid.i removed my engine by setting my rear tire on a bike jack or lift, then having a wooden block to support the motor. i removed all motor mounts and electrical wiring, throttle bodies also fuel lines. then slowly lift the rear tire raising the whole frame from the motor.after making sure all wiring is clear . slowly slide motor away from frame.unfortunately for me due to rod failure i got real good at this,igot this procedure down to 1 1/2 hours or less.
jay
NOX
posted March 30, 2008 12:03 PM
With race body work, I can have my motor out in 30 to 45 min. That is with a Adams pan, or Koenig pan on the bike......, using a transmission jack. Takes long to put it back in, just making sure all is routed right, and no kinks, etc.
Just rebuilt a stock motor this Friday.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
ninja12
posted March 31, 2008 06:15 AM
don't remove the TB or fuel lines with the engine. Saves some time on removal and install.
NOX
posted March 31, 2008 09:12 PM
exactly
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
0.33022713661194 seconds processing time
