BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Full exaust - Power? NEW TOPIC NEW POLL POST REPLY
Fantomet
zx12r2000
posted March 13, 2008 02:02 PM
Ive got a 2000mod.
Just bought a KNfilter, full Muzzy exaust and a Powercomm.
Any idea what kind of power i will get?
KNfilter
Full Muzzy
Pc3
180rwhp
Step aside folks - comin through!!
oldkawboy
posted March 13, 2008 03:27 PM
Depending on how tight the motor is, how good the map is and whether the dyno is happy or not.........175 to 180hp is my guess.
Dan
zxlnt
posted March 13, 2008 11:04 PM
That will be a real happy dyno. Try low to mid 170's...
oldkawboy
posted March 14, 2008 04:20 AM
Okay then.....a sad dyno will show 165 to 170hp. It was just my guess!
BTW, I've seen a bunch of bolt -on 12's making high 170's over the past seven years on several different dynos.
Dan
riteristrob
posted March 14, 2008 06:39 AM
2002 with full muzzy exhaust, PC3r awesome map, and BMC street filters, made 173.4 hp at 9820 rpms on a DJ250 dyno. I think a 2000 will do better.
Fantomet
zx12r2000
posted March 14, 2008 06:50 AM
Sounds good! What would you think your bike would do stock? That map, is it custom or is it from Powcomm.com? Why do you think 2000 will do better?
KNfilter
Full Muzzy
Pc3
180rwhp
psycho1122
posted March 15, 2008 06:59 AM
172 corrected. The pipe will give you close to 25 h.p. gain above 11,000 rpm with proper mapping.
zx12mark
posted March 15, 2008 11:09 AM
one thing you can be sure of is it will run like a motherfucker.SO HIT IT. -----------------
that is if your not too scared.
tshultz
posted March 15, 2008 01:04 PM
wait till you take of the stock pipe and feel wow heavy it is
tshultz
posted March 15, 2008 01:19 PM
what the hell was I typing
Fantomet
zx12r2000
posted March 16, 2008 03:10 AM
Im not scared! See you in hell.
KNfilter
Full Muzzy
Pc3
180rwhp
ZXLNT
posted March 16, 2008 10:51 AM
Definately that much or more. The stock pipe strangles the engine up top and power falls off bad. With an aftermarket exhaust the power peak is higher and it holds power to the rev limiter.... instead of falling on its face...
Hells Dark Lord
living life, and loving it.
posted March 16, 2008 10:52 AM
Dan
my 02 made 154 stock, and with full Muzzy, PC, KN filter with Muzzy mechanical ignition set at +4 degrees and custom map made at Stock, Mild to Wild in Jax, made 180.1 hp
My 01 makes 183.3 with a full TiForce, PC, stacks, and KN filters, and some Roger tweaking.....dont know what it made stock....and that was mapped in Nashville, TN....not at sea level.
My guess is that high 170's is very do able.....with the right combination of parts and tuneing....what do you think Dan? hehehehe
Fantomet
zx12r2000
posted March 16, 2008 02:35 PM
Do you have a picture mr Dark Lord? Ps do you have a lot of bikes??
KNfilter
Full Muzzy
Pc3
180rwhp
Hells Dark Lord
posted March 16, 2008 03:05 PM
dont have alot of bikes, just enough to keep me riding.....and I do have some pics....
my 01
My 02 that is now deceased.....
My 04 ZX10R
My 06 Vulcan Nomad, which by way is up for sale.....
oldkawboy
posted March 16, 2008 04:54 PM
HDL,
No doubt that fine tuning with Rog helped net the 183..........he is good!
As always, your bikes look great!
Dan
tshultz
posted March 16, 2008 05:55 PM
That is a bad ass looking zx10r
Phantom13
posted March 17, 2008 02:16 PM
It all varies....
Dyno's vary... sometimes up to 10rwhp even with the same dyno model (I've experienced this personally in the past).
Correction factors is a big one too, STD will "show" higher numbers than SAE, but SAE is a more ACCURATE correction method.
Tuning will vary. Some tuners will lean it out to make big numbers on the dyno, but then on the street it will run like crap, Some will tune it so it runs good in the real world, but then you get lower numbers on the dyno. Don't be fooled, the HP number isn't what's important, the optimum A/F for the real world is what you want to be concerned with.
There are plenty more variables that will effect the power output of the bike on the dyno... these are just some of the most common.
As for my personal prediction for your bike...
I'd say with a GOOD custom map.... 173-176rwhp SAE on a DJ250. The K&N's are too restrictive and the Muzzy pipe is mediocre. With the RIGHT filters and pipe, 178-181rwhp SAE is possible.
Highest I've seen with a 10000000% unopened, bone stock, valve cover never off ZX-12R with JUST a pipe, filters, pc3usb is 183.5rwhp SAE on HAPPY DJ250.
"The only place Success comes
before Work is inside the Dictionary."
  Ignore this member    Click here to visit Phantom13's homepage.
Hells Dark Lord
posted March 17, 2008 04:31 PM
thanks Dan....isnt any sense in having them if your not gonna ride them and take care of them......
And I have no doubt that Roger played a HUGE part in getting that much power from both of my 12's he is a stickler for details.....
tshultz, thanks, its not quite done, all of the armor and handleing mods are done, now I need to work on power and brakes....looking at putting ZX14 calipers on it, with Brake Tech Axis rotors, and prolly a full Micron exhaust as I cant get a header for my AP slip on, and I can get a micron at cost....my Micron on my 600 made decent power and sounded good.....put the pipe on it and a PC and have it mapped for this elevation, sould help it out...
Fantomet
zx12r2000
posted March 18, 2008 12:48 AM
Tonight it came 10cm(3 inches) snow here in Norway! It went from spring till winter in no time! DOH!!!
KNfilter
Full Muzzy
Pc3
180rwhp
Hells Dark Lord
posted March 18, 2008 10:16 PM
fuk snow, I went home to Michigan over the holidays and a blizzard came in, I drove through MI in snow, IL in fog, And most of OK in ice......I will stay in the deep south, you all can have the snow.....
Dragonknee
posted March 23, 2008 03:55 PM
I have a 2002 with a hindle full system and a power commander and it was dyno'd by a local legend named Mike Valesco at brothers yamaha in bremerton washington. He worked for quite a while to get the numbers that I got...but heres the dyno chart given to me.... the torque and the hp are smooth and it runs better than any bike I have ever owned.... even if the numbers differ from std to sae... I know that I love my bike and the way it runs.... and it hits dam hard at 7500 rpm.... oh yea......
[URL=http://imageshack.us][/URL]
Ignorance more frequently begets confidence than does knowledge!
(Charles Darwin-1871)
Hells Dark Lord
posted March 23, 2008 05:53 PM
thats some serious TQ numbers for a stock motor, I have never seen a stock motor put out over 100 ft lbs of TQ....I am not sure how to convert those numbers to SAE...
Megabyte
posted March 23, 2008 06:10 PM
Mike Velasco is a local legend. He built my 212 rwhp 1361, 3 years ago, and she's still going strong.
Dragonknee
posted March 24, 2008 05:21 AM
I have had people say that its not right and those who say its all in the tuner who does the work and the amount of time he puts into it..... I know that the bike flat out gets with the program and short of a big bore kit its as good as I need for now.... oh yea.....
0.23807597160339 seconds processing time
