BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Installed my Bear Stacks NEW TOPIC NEW POLL POST REPLY
Zhooligan
Post Whore Extraordinaire!
posted July 23, 2002 07:53 PM
Well I finally got the Bear stacks installed on my 1361 motor. Won't know how it all works for probably another couple weeks as I am still breaking the motor in.
The stacks were a bit of a bitch because the stroker motor raises the injector bodies so I had to find some big ass O rings to insure a seal. Also if you are installing them the stock bolts don't work. The heads are to big so allen head bolts are a must. Bear might consider selling them with the stacks. The fit is super tight. I used a little dab of grease and pulled the stacks into place with the bolts.
They look trick at the very least! I will post numbers in a couple of weeks
future; -- Youth is forever.
RAC4IT
Bergie
posted July 24, 2002 09:30 AM
Surprised yours didn't fit so easily. Mine dropped right into place (aside from the bolt problem you mentioned). I detailed the install on the following page:
http://www.dontbescaredracing.com/bearstacks
madmike
posted July 24, 2002 10:25 AM
Mine also fit great, take them in and out a couple of times and then they fit awsome, make sure the bolts are tight, ask Kawachan about that deal, he can show you pictures to prove what damage the bolt can do.....
Mad Mike
kawachan
posted July 24, 2002 10:52 AM
Mad Mike
You freakin' better use some Loctite or the like to install those new bolts!! My lil slip up is the reason I'm "bikeless" right now. Have you ever seen what a loose bolt in your motor will do at 12000 RPM??
You don't want to find out......
New head, can you say it??
RED NINJAS RULE!!
ZHooligan
posted July 24, 2002 01:19 PM
Thanks for the loctite tip.
0.22984099388123 seconds processing time
