BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Stealth... NEW TOPIC NEW POLL POST REPLY
twista
" Get up, and Stay up ! "
posted January 31, 2008 11:42 PM
Stealth...
Just got my Stealth 45 Tooth Sprocket in the Mail today,, nice looking piece,, it is going on my A1 along with the new 17 front Vortex and the EK DVX2 Chain,, so i have a 17 toofer if there are any takers ,, has about 2K on it,, my question is:
what is the easy and proper way to remove the front sprocket without an impact?
last time i was at my buddy shop where the bike was stored during the rebuild,, but i dont have a compressor so? also i here that it shouldnt be in gear etc,, and to chock the wheel,, anyone? thanx
posted February 01, 2008 06:51 AM
get a breaker bar, and maybe a piece of pipe. stick a 2x4 thru the rear wheel. get a buddy to sit on bike and stand on the rear brakes(helps if you have a rear stand) use precision brute force with the breaker bar on the nut after you bend the tabs back
twista
posted February 01, 2008 07:35 AM        Edited By: twista on 1 Feb 2008 07:36
Sounds good,, thanx Scott Vic
stupid question,, in gear?
posted February 01, 2008 10:31 AM
i wouldnt try it in gear. i allways put it in neutral just to be safe. and if you do find an impact, DONT put the nut back on with it.... i think i might have wrote something very similar to this not too long ago on Dales site.. hmmm
Heavy AK
posted February 01, 2008 02:50 PM
front sprocket
You never want to use the rear stand....you can't get enough weight on it to keep the rear tire from moving.
move the rear tire forward in the swingarm to get some slack
bend the metal tabs back from the nut
leave the bike on the ground
sit on the seat
hold the rear brake
remove the nut with a long torque wrench
easy as pie. The rear stand thing will get a lot of people because they will forget that without the weight of the bike and rider loading the tire you can't keep it from spinning.
A little GAS is a good thing!
posted February 01, 2008 02:53 PM
you didnt read the part about the 2x4 did you?....
Megabyte
posted February 01, 2008 03:47 PM
First time I took the front sprocket off, I tried a 1'' breaker bar w/a 4ft pipe, no go. Next, I put an impact wrench on it, and she spun right off,
twista
posted February 01, 2008 07:55 PM
Im thinking that since its been off recently (2K) i should have a problem with it,, that is exactly how i got the clutch nut off.. we will see,, maybe tackle it after the Superbowl!
thanx for the input guys!
posted February 01, 2008 09:27 PM
i didnt have to use an impact on either of those... get a longer bar or start going to the gym lol:P
seriously, a 2x4 thru the rear wheel wont let the wheel turn(think back to when you used to throw sticks thru the spokes on your buddys pedal bikes to lock a wheel up on them)
if you are scared about paint, wrap it in a towel.
twista
posted February 01, 2008 09:57 PM
thats what im gonna do,, might even start lifting weights again LOL thanx Scott
Vic
ninja12
posted February 03, 2008 06:57 AM
harbor freight has a electric impact, work great for sprockets, clutch baskets and car tires.
http://www.harborfreightusa.com/usa/itemdisplay/displayItem.do?itemid=45252&CategoryName=&SubCategoryName=
0.28828692436218 seconds processing time
