BIKELAND > FORUMS > ZX12R ZONE.com > Thread: rear fender removal? NEW TOPIC NEW POLL POST REPLY
MO
posted November 01, 2001 06:39 PM
where to relocate the computor? or do I need the eliminator kit? I have a nice piece of black sheet metal I can trim to fit to cover the unsightly hack job I've seen so often
KW
  Ignore this member    Click here to send MO an AIM message.
Dino
posted November 01, 2001 10:10 PM
There's many ways to do it...I put a divider between the seat bolts and seat, and stuck the ECU in there...perfect fit!!
wilson1
posted November 02, 2001 03:35 AM
remove ecu from rubber turn rubber so that tits are up drill bottom of tool box to that pattern then mount ecu to bottom of tool box
MO
posted November 02, 2001 05:35 AM
Cool, but it will have to wait till after work or even saturday cause tonight is race night! I was foolin with the idea of lowering the front fender 3/8 what do you think the miminum tire to fender clearence allowable would be I want to lower the forks in the triple tree and have less chance of bottoming out and knocking it loose
KW
0.22363305091858 seconds processing time
