BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 05 ZX-12 ECUs...can they be rev extended NEW TOPIC NEW POLL POST REPLY
shiphteey
posted October 02, 2007 06:33 PM
600 rpms like the 16 bit ecus on the earlier one? Asking for Dr. Ryan Scarsella since he can't post right now.
A.
Gemini Motorcycles
capt10ed
posted October 03, 2007 05:30 AM
I have an 04 zx-12 that Dave O modified.
I believe the 04/05 ecu's are the same
and 204.5 in the mile.
TRNorBRN6001
posted October 03, 2007 05:52 AM
I heard Dave O is over with Lee now, but I could be wrong.
TFA 200MPH CLUB MEMBER!
capt10ed
posted October 03, 2007 03:29 PM
When Dave did my ecu for me he was living in Mass.
Lee is in NC
PM me if you need his phone#,
supra5677
posted October 03, 2007 03:57 PM
forget that use Ridge Racer, you can get 1000 rpms..
shiphteey
posted October 03, 2007 06:57 PM
Holy SHIT, 1000 MORE than STOCK!?!?! WTF?!?!!?
A.
Gemini Motorcycles
capt10ed
posted October 04, 2007 03:28 AM
Supra , Ridge racer did crack the code for the ecu's BUT not for the 04/05.
RR Great job !!!!
ridgeracer
posted October 04, 2007 05:49 AM
Thanks, and you are correct what I did only works up through the B2 model.
To be clear, I found the map values that allow you to set at what RPM the injectors cut out and the coils turn off. (They turn off at different RPMs) I also found a map 'switch' that allows you to turn off the rev limit checking all together and was able to run the ECU up to 15,000 RPMs, the limit of my bench test equipment with the switch off.
But, in my opinion, the design limits of the ECU in no way implies what the real mechanical limits of the actual engine are.
supra5677
posted October 04, 2007 12:11 PM
real mechanical limits of engine is approx. 4500 fpm ..
zx12dak
posted October 04, 2007 07:33 PM        Edited By: zx12dak on 4 Oct 2007 20:33
Has anyone here had a stock (piped/PC) bike on the dyno? Is the raised RPM useful. My bike made peak HP at redline (11500-11600). Makes me wonder if going up a couple hundred RPM would help at the track, like to hold a gear thru the traps instead of shifting right before it.
supra5677
posted October 07, 2007 08:39 AM
yes when I had my bike extended by 640 rpms I hit 200mph on the dyno still accelerating with a lot to go. 17/44 gearing. I have since extended it to 1000 more rpms so we shall see..
0.2332489490509 seconds processing time
