BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 12R A1 injectors NEW TOPIC NEW POLL POST REPLY
keith
posted October 02, 2007 08:22 AM
12R A1 injectors
I read somewhere, but I can't find it now, that the A1 (Y2K) model 12 has 330cc injectors. When we dyno'd my 1270 motor to 200 rwhp it was on 90-92% duty cycle so I want to upgrade a bit. I no longer have the 1270 motor having launched a rod through the front of the cases at the top end of the strip. I am now running a stock motor with Carrillos and forged pistons with a 50 shot and want to go for a bit more gas next season thats why I need the standard injector spec. In the manual it just says Denso but no capacity. Went 9.08/155 at the weekend but want to dip into the eights! Keith
posted October 02, 2007 08:47 AM
what fuel pump are you running? stock?
keith
posted October 02, 2007 09:00 AM
Muzzy high output pump. Ran 207.9 recently hitting gas in 4th gear. One and a half mile run. Keith
supra5677
posted October 02, 2007 09:02 AM
I would keep the stock injectors and go with the muzzy pump...
keith
posted October 02, 2007 09:22 AM
Hi Supra - thats the kit in the bike now but it goes lean if I go up to a 60 shot and I want to run 80 - 100 shot.
TRNorBRN6001
posted October 02, 2007 09:50 AM
Maybe check fuel pressure just to make sure.
If you have stock pistons be careful over a 70 shot. Also if you have stock valves and springs maybe change them out as well.
TFA 200MPH CLUB MEMBER!
keith
posted October 02, 2007 11:31 AM
I'll check the fuel pressure, stock is 41 psi with the motor running? so, what size are the stock injectors?
shiphteey
posted October 02, 2007 11:33 AM
On my A1 w/muzzy fuel pump and a 40 shot, duty cycle peaks at 80% right before the limiter, over and over.
Gemini Motorcycles
TRNorBRN6001
posted October 02, 2007 12:02 PM
Off the top of my head here at work I think around 215-230CC, just depending. There was a thread a little bit back on injector cleaning and flow testing. Mine were on the low side while Entropy's and a couple others were on the higher. RC did the cleaning and flow test. I think around a hundred bucks or so for a set. If you can not find it or no one answers, I'll look it up when I get home.
I think the newer bikes had larger injectors, but I do not think they dropped in to easy on the 00-01 bikes. Entropy may still have a set for sale.
TRNorBRN6001
posted October 02, 2007 12:19 PM
Oops, I am probably wrong up there on the 215-230. I am getting old fast!
posted October 02, 2007 12:34 PM        Edited By: entropy on 2 Oct 2007 13:41
Gary got most of it right
Y2K injectors
"June 2005: received '00 injectors back from RC Engineering:
before/after cleaning
325 / 330
311 / 329
325 / 331
320 / 330"
interestingly, when i had the SAME injectors cleaned again
Nov 2006: received '00 injectors back from RC:
331 / 336
311 / 334
328 / 335
319 / 335
when i installed the RC370's
- Duty cycle at 11,000 dropped to 78-80% (RC370's) from 88-90% (OEM inj)
I gotta laugh at myself and my anal retentive record keeping LOL
psycho1122
posted October 03, 2007 07:31 AM
I have two set's of stock 00' injectors...
320cc and 330cc
keith
posted October 03, 2007 10:36 AM
Thanks guys, that was the answer(s) I was looking for. Entropy, did the 370's go in without much modding, if so who made them? Good to hear from you, Keith (71 next week and still doing PB's year on year)
posted October 04, 2007 03:54 AM
keith,
RC Engineering 370's
It is a pretty close fit between the electrical connection on the injector and the airbox, but doable.
I had a small bit of lathe work done on the injectors, but alternatively you could mod the electrical connector. very doable.
BTW i do have a brand new set of the 04-05 injectors for sale. They don't easily fit Y2K
keith
posted October 04, 2007 09:35 AM
Ta very much
0.30388712882996 seconds processing time
