BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Throttle body synch NEW TOPIC NEW POLL POST REPLY
Texas12R
posted September 14, 2007 07:38 AM
Throttle body synch
I know how notorious the old kz was, and I'm sure it was because of the mechanical
linkage, but Im curious about your experience with the 12 throttle bodies.....as far as
observations concerning synchronization stability
....Michael
capt10ed
posted September 14, 2007 08:43 PM
Good question
I use to synck the carb on my old zx11 every couple of months.
My 12's throtle bodies has not be adjusted since new and the bike now has 14,000.
the mirrors are crystel clear on the highway. This bike is SMOOOOTH
and 204.5 in the mile.
eastbaydave
posted September 15, 2007 06:42 AM
same here....7 years & 9K and never done...works great!
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
Texas12R
posted September 15, 2007 10:08 AM
I havent put the merc manometer on mine and I dont have the cool 90 deg adjusting
driver so I wasnt going to buy one just to find that I really wont need to perform
this procedure.
as always I appreciate your views and input....
tuusinii
posted September 15, 2007 11:30 PM
I sync them at every 4-8k km. Usually they aren't much off, but syncing them keeps the engine just a little bit smoother... If You haven't done it You ca't say if it helps or not. It's the same thing as with valve clearances the engine works even if You don't check it by You still want to do it!
Texas12R
posted September 16, 2007 02:17 AM
Excellent point Tim!
lonniemac
posted September 22, 2007 07:53 AM
if you dragrace, the sync will be better for a smother launch. maintaining a smooth stall rpm, and the cranckshaft is more balanced with the same power on each journal.
shiggsy
posted September 22, 2007 10:10 AM
Does anybody know why the pipes that you hook the vac gauges up to (right hand ones as you sit on the bike) have larger bores on the outer throttle bodies than the inner throttle bodies ?
0.21719098091125 seconds processing time
