BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Ping Psycho1122 NEW TOPIC NEW POLL POST REPLY
supra5677
posted July 25, 2007 08:31 AM
Ping Psycho1122
check pm..
psycho1122
posted July 25, 2007 07:22 PM
Got it...
chavcat
posted July 09, 2009 06:25 PM
Psycho1122 - have you had any problems starting your hi-comp motor> Are you still using just the OEM battery?
psycho1122
posted July 11, 2009 07:53 AM
No problems starting the engine. The ONLY time I ever had it turn over slow was on a drag nite. Temps were warm 80's - low 90's and I had made a few quick passes with little cool down time or running time to recharge battery.
I run a "Deka" Glass Mat Tech. battery. Always on a battery tender.
chavcat
posted July 11, 2009 10:36 AM
Psycho = Sounds good. What comp is your motor? Cranking pressure? Cams? What have you done to the head? Running a Muzzy fuel pump I gather?
Thanks!
psycho1122
posted July 14, 2009 07:33 PM
CR is close to 14:1, Cranking pressure is / was 230-235 per hole cold, cams are stock 105.5 in. / 100 ex. Head has only cleaned up intake ports and a Muzzy fuel pump.
chavcat
posted July 15, 2009 04:39 PM
Impressive! Are you using a base gasket?
psycho1122
posted July 16, 2009 05:36 AM
No.....PTH is just under .030
posted July 16, 2009 12:06 PM
that ole psycho guy...
livin' on the edge, and livin' LARGE!
psycho1122
posted July 17, 2009 05:11 AM        Edited By: psycho1122 on 17 Jul 2009 13:22
Hey entropy;
well, maybe.....the last time I pulled the head, the piston tops had a bare shinny spot on the exhust side quench area. Very small with no carbon build up. I called and talked to someone we would consider very expirienced in this area (Doug)......It was a very cool response....."That's PERFECT!" he said. So I stayed with the same combo / set up.
Hmmm, that was OVER 12,000+ miles and 6 years ago. It will still put down over 190 h.p. and 111 ft. lbs on a bad day and a stingy dyno! Oil pressure still holds 35-40 psi at 4,000 rpm / 80+ at redline depending on overall temp and time on oil.
I wonder how long it will live?!?
posted July 17, 2009 03:23 PM
what's up psycho!
you definitely have the combo!
Is this the year you are gonna run the Texas Mile?
psycho1122
posted July 18, 2009 07:19 AM
I am putting things together to make a run in spring of 2010!
I need to make some strides with the Ninja Hauler.
posted July 18, 2009 11:20 PM
Oct is generally better, but then again, last Mar was the best weather yet
what's a "Ninja Hauler"?
psycho1122
posted July 19, 2009 05:29 AM        Edited By: psycho1122 on 19 Jul 2009 13:30
My good 'ol 96 Dodge Dakota.
196,000 miles on it. Just put in an Auburn 3:55 posi. on the rear end rebuild. Driveshaft just received it's first new Spicer universals and a rebalance. Looks like the 5 speed manual needs some work also.....some kind of bearing noise and the synchros have started to act up after all these years of hard shifting! The original front rotors and rear drums need to be replaced (Updated), belts, hoses and new tires on the 17" R/T wheels I just got for it.
One good thing is the 5.2 bullit still runs strong! Dynoed at 275 h.p. not bad RWHP for a uncorked stocker w/ all the miles!!
So what do you do?!? Keep the good 'ol runner with no payment and cheap insurance / tags or go with something newer?!?
I do like the Dakota....it ran high 14's BEFORE the posi + gears and still gave 20 mpg.
posted July 19, 2009 11:19 AM        Edited By: entropy on 19 Jul 2009 19:20
I know what I would do! Keep the good ole runner!
my copcar just turned 170,000 and i have no qualms about towing a a couple bikes to Caribou Maine (4800 mi round trip)
my daughter's Cherokee just turned 200,000 and she has no thoughts about trading it in.
we like the "ole runners"
posted July 22, 2009 06:23 PM
my 94 dakota
doing some upgrades this winter if the budget allows. D44 SAS, and a D60 out back, probly go with 4.10 gears, the 38s are kinda hard on power(and light duty running gear)
Im really wanting to find a junkyard 360 magnum to build to replace the 318.... hmmm 408 stroker? someday....
0.24746203422546 seconds processing time
