BIKELAND > FORUMS > ZX12R ZONE.com > Thread: valve cover gasket removal NEW TOPIC NEW POLL POST REPLY
ponyman
posted July 19, 2007 06:25 PM
1.has anyone changed there valve cover on their zx12r
2.how hard was it to change
3.cam change(any attempts and how hard of a procedure)
tuusinii
posted July 20, 2007 12:43 AM
No biggies, just take everything off and a good clean and some RTV and the new one in. Just be sure that the leak comes from thecover casket, because there are man examples off the cam position sensor casket leaking and not the cover casket. None of those is really hard but time consuming because of many bolts and be carefull when checking cam timing if the cams are off.
kawasabi
posted July 20, 2007 05:58 AM
Bin there, did that.... Easy but time consuming.
posted July 20, 2007 07:45 AM
My experience is that the seals under the bolt heads thin out and lower the clamping force which allows the cover gasket to weap oil! So if you plan to change the gasket, make sure you change all of the ?? 6 or 7 washers under the bolts
0.51412796974182 seconds processing time
