BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Clutch problem NEW TOPIC NEW POLL POST REPLY
ZX12-5807
posted July 11, 2007 07:53 PM
Clutch problem
I am hoping somebody on here has seen this problem before and can offer some help. Problem is the clutch puller shaft is pulling through the actuator arm. I am running stock springs in the clutch and I have gone throught several actauator arms in the last two months. I have replace every bearing in the clutch cover and clutch assembly. I make sure the clutch is adjusted per the manual. Has anyone seen or had this problem. What is the fix?
2001 ZX12 1287cc
2001 ZX12 1317cc Lee's head
ZXLNT
posted July 12, 2007 01:01 AM
Probably a stack height problem in that the puller actuator arm angle isn't correct.
ZX12-5807
posted August 06, 2007 07:38 PM
My clutch stack height measures 57.5mm ( spec is 56.8 to 57.6). Does anyone have any other suggestions?
2001 ZX12 1287cc
supra5677
posted August 06, 2007 07:46 PM
try the muzzy clutch
ZX12-5807
posted August 06, 2007 08:09 PM
I tried the muzzy clutch and the puller still ate through the arm
2001 ZX12 1287cc
Wolf Racing
posted August 06, 2007 11:46 PM
Hi,
Is it a standard clutch setup or lock up.
If it's standard, check the puller rod head. It must have a sharp square edge on the back of the head. Any wear, replace it.
There should be a washre under the actuator arm on the top entry to the cover. Make sure it's there.
Let me know??
Wolf.
  Ignore this member    Click here to visit Wolf Racing's homepage.
Texas12R
posted August 07, 2007 03:45 AM
this is a good read.....Im not sure if your problem is related
http://www.bikeland.org/board/viewthread.php?FID=1&TID=32723&set_time=
0.22846102714539 seconds processing time
