BIKELAND > FORUMS > ZX12R ZONE.com > Thread: can anyone suggest where to get a +12v lead behind headlight assembly? NEW TOPIC NEW POLL POST REPLY
TReMor
Dazed and Confused
posted June 20, 2002 01:07 PM        Edited By: TReMor on 20 Jun 2002 14:12
Can anyone suggest where to get a +12v lead behind the headlight assembly?
I got a Kriss headlight modulator, and I want to install it tonight. To connect power it needs a +12v accessory terminal or fused lead. Since I know a lot of you guys have wired in radar detectors and such, I was hoping you could share which lead you used. It'll save me dinking around with a voltmeter. I remember reading something about an additional port in the fuse panel I think, but I did a search and couldn't find it.
Anyway, any help would be much appreciated.
Tim
BTW, in case it matters, my bike is a 2002 model in the fastest color combo...black'n'gold.
edit: Here's a link to the wiring diagram. It's an Acrobat file http://www.kriss.com/zHM20wire.pdf
  Ignore this member    Click here to send TReMor an AIM message.
frEEk
posted June 20, 2002 01:23 PM
yes, there is a terminal in the fuse box marked ACC that is unused. 10A i believe. just stick a female connector in the existing connector black and it will look like stock. cant say fer sure if it's the smae on the 2002 tho.
TReMor
Dazed and Confused
posted June 20, 2002 01:58 PM
Thanks Freek...I appreciate it.
Tim
0.24405002593994 seconds processing time
