BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Another 12 that won't start. NEW TOPIC NEW POLL POST REPLY
rcwash1
posted May 08, 2007 11:54 AM
Guys the old girl won't start. She just turns over but no firing. I've tried to check the fuel pump, but it doesn't seem to be working. When I disconnect the fuel line from the tank is fuel supposed to flow through the pump or does it have to be on? Because I'm not getting much out and I am extremely leary about jumping the fuel pump relay. So is there another safe way to do it or where can I get another without getting gouged by the dealer. I starting to get the blues from reading all of the bad ECU posts.
buddy
posted May 08, 2007 12:51 PM
I think there will be no fuel flow unless the pump is activated, at least that is the way my 01 worked. What year is your 12? I would think you should be able to turn the key on and have fuel flow from the disconnected line, if the pump works. If thats not right, I'm sure someone will jump on this quickly.
rcwash1
posted May 08, 2007 12:53 PM
It's a '05, with less than 1000 miles. All of my riding pals sold there bikes when I bought mine.
posted May 08, 2007 02:56 PM
Trade it for a ZX14
posted May 08, 2007 03:08 PM
You are right to be wary of jumping the realy. It's an effective way to troubleshoot the pump, but if you do it wrong, you'll toast the ECU. I'm not near my notes, so I don't want to guess wring on whch wires to tell you, but Vincent or entropy must know......
Fuel won't flow without the pump activated. FIRST check for spark. That will send you in the right direction without much work.
Doug
blitzkrieg
Road kill = Free lunch.
posted May 08, 2007 03:19 PM
The first question I always ask is what happened between now and the last time the bike ran?
rcwash1
posted May 08, 2007 03:45 PM
Well, I tried the pump with the key and nothing from the pump. I tried to switch the ECU relay and nothing. I took the ECU relay out and the bike responded like I would think.
rcwash1
posted May 08, 2007 06:06 PM
Nothing really. Rode sometime in Feb. while it was warm. I pull it out wash it up and go to start and nothing happens. This was two weeks ago.
aliveagain
posted May 08, 2007 06:29 PM
Try using an air hose on all the handlebar components and also pull the coils and blow out the spark plug holes.
tcchin
posted May 08, 2007 11:46 PM
The fuel pump should run for three seconds when the key is turned on. This allows the fuel rail to come up to pressure. If this isn't happening, I'd look at some fuses and the tipover sensor.
Jumping the fuel pump relay is pretty straightforward - just pull the relay and jumper the two heavy-gauge wires in the connector together. I can't read the wire colors in my PDF manual, and I can't remember off-hand what the colors are, but it was pretty obvious. The supply side of the relay is switched power, so the ignition will need to be on.
Texas12R
posted May 09, 2007 03:15 AM
This Might be worth reading. I believe it was the ignition switch without reading it all again.
http://www.bikeland.org/board/viewthread.php?FID=1&TID=25558&set_time=
supra5677
posted May 09, 2007 07:27 AM
Damn dude this is unbelievable.. I had the shop pull my head off because my bike wouldnt start.. Did spark test no spark.. Fuel pump also doesnt come on when turning the key like it use to. MY IGNITION SWITCH IS LOSE AND OCCASIONALLY DOES spark.. Since I have the kawi extended warranty Im going to get new Switch.. ( I should have listened to my uncle before I put the cam in he told me my switch was bad) live and learn..
supra
posted May 10, 2007 06:42 PM
Trade it for a ZX14
jus1975
posted May 11, 2007 06:27 AM
Ah hell.
I can proudly say I'm an expert in this department.(lol)
I had the same problem. It was a combination of things. The fuel pump relay. But the turn over sensor can cause the no fuel and no spark problem. And lastly the ingnition switch was bad.
Try the ignition switch since its under warranty and also buy a fuel pump relay, its not that expensive. And while you wait on the ignition switch test the turn over sensor.
I dont have my manual with me now but if you need help let me know.
supra5677
posted May 11, 2007 09:09 AM
Iv'e beaten 2 zx14's to me they are not impressive.. roll on from 90 mph on up
posted May 11, 2007 12:07 PM
The 2 Relays on top are the same! Switch them! That will show if a relay is bad. I have "Toasted" an ECU (Well at least the the Pump part and had to permanently wire the Relay to make it run.
I will ask the Stupid Questions!
You have checked all of your fuses in the Top Box?
You have removed the Battery and checked the Fuse there and made sure the Battery is over 12 volts?
You lifted up the fuel tank and made sure the connectors to the Pump and fuel gauge are clean and tight!
supra5677
posted May 11, 2007 12:14 PM
yes...
rcwash1
posted May 11, 2007 02:41 PM
I switched the relays - nothing.
All fuses on top good
I haven't checked the one near the batt. (Work)
All connections have been wiggled, probed, prayed upon and blown. (with air)
and the batt. volts are high.
F_Sik
posted May 14, 2007 08:59 AM
guys the problem is that its a 12
As long as y'all don't have any kryptonite/I'm gonna be alright.
  Ignore this member    Click here to send F_Sik an AIM message.
supra5677
posted May 14, 2007 09:48 AM
does your motor turn and not start?
rcwash1
posted May 16, 2007 03:46 PM
Yep, motor turning, no starting.
posted May 16, 2007 04:08 PM
DId you check for SPARK yet?
Texas12R
posted May 16, 2007 04:28 PM
1 Do you have a manual?
2 Do you know about the FI fault code and how to enter dealer modes
3 Mr Hills advise "KISS" I say that with a smile .....Kept it simple silly ( paraphraze)
jhinderliter
Hacksaw
posted May 17, 2007 08:31 AM
i havent hung out here in a bit but this post begs the question doesnt it?
why would you even post this on a 'please help my bike wont start' thread?
good luck with the bike RC
peace
blitzkrieg
posted May 17, 2007 10:25 AM
Well you answered your question replying to mine.
You got water somewhere it ain't supposed to be. I agree, I'd look at the ignition switch and kill switch first. Get out your ohmmeter and manual, shouldn't take long to track down.
And funny and true story (at least if you weren't him):
I know of a guy that washed his bike and it wouldn't start afterwards.
He pretty much disassembled the bike trying to figure out what the problem was. Damn thing was not getting spark, but everything checked out. Switched ECU's, you name it.
After a day and a half he discovered the culprit (and actually admitted it):
When he was drying the bike off he must have toggled the kill switch on.
All that work and all along the kill switch was on.
BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Another 12 that won\'t start. NEW TOPIC NEW POLL POST REPLY
0.28040909767151 seconds processing time
