BIKELAND > FORUMS > ZX12R ZONE.com > Thread: I Guys i have questions (air awitching) NEW TOPIC NEW POLL POST REPLY
stef12rr
posted April 22, 2007 04:55 PM
What the air switching do? on zx 2004
and i unplug the air switch , and put blockoff plate and Fi light came on ?
Can i bypass it ?
thank
posted April 22, 2007 11:40 PM
air switch??? what is that???
could you explain a bit??
stef12rr
posted April 23, 2007 05:11 PM
Yes i could on the valve cover on zx 12 2004 and 2005 Kawa they put a electric air switching valve, instead of air switching valve activate by vacuum when i unplug the electrique cable the FI light came on, so i had no choice to plug it back then a taught that was my problem for the rought engine at 7000 rpm
but today i check the main TPS and it was off by .111 volt
i put it in the spec. and the engine when better at 1.06 volt so i lower the voltage at 1.01volt when it's start to rain, i had no chance to try the bike today, tomorow !!
and i check my sub throttle sensor at idle (1000 rpm) i have .69 volts DC in the book the spec. is .48 to .52 volts i try to put it in the spec. but it can't go any lower,
is it bad or i can live with it ?
the story is when i bought the bike in 2004 i had a the same problem at 7000 rpm, i when to the dealer 2 times and never solve the problem, until i put a power commander seem solve the problem.
what do thing entropy
0.24271011352539 seconds processing time
