BIKELAND > FORUMS > ZX12R ZONE.com > Thread: USB cable NEW TOPIC NEW POLL POST REPLY
aliveagain
posted April 03, 2007 05:09 PM
USB cable
I reset my tps and now have to reset the setting on the usb power commander.I need to go from the garage to my downstairs computer,about 45 feet.My old cable won't work on the new computer since they no longer have coaxle ports.Anyone know where I can get a long usb cable?
UTZX12R
posted April 03, 2007 05:35 PM
45' is too far for USB. Max length is 5 meters. See http://www.usb.org/about/faq/ans5
I've read of USB extenders, but never used one. YMMV.
aliveagain
posted April 03, 2007 06:42 PM
Why is 45' too far.Does it bias the signal from the extra resistance?
posted April 03, 2007 08:06 PM
Im in the same boat as you. I took the desktop computer out to the garage last time I tried to play around with a power commander. not fun at all eh?
tuusinii
posted April 04, 2007 01:31 AM
It takes too much time for the signal to travel so it gets out of sync if the cable is too long.
ridgeracer
posted April 04, 2007 06:41 AM
You can use a USB hub as a repeater to extend the length.
Using three 16' (5m) cables and two hubs you could run 48'. The specified limit using this scheme is five segments of 5m each with 4 hubs.
Y2KZX12R
CompetitionCNC.com
posted April 04, 2007 06:48 AM
Pete, hit one of the computer shows around here and pick up a used laptop.
You dont need much of a laptop for programing a pc-III.
They have some for $100 or so.
Y2KZX12R
CompetitionCNC.com
aliveagain
posted April 04, 2007 11:57 AM
Y2KZX12R,never heard of a computer show around here.I can't ride until I reset the tps in the power commander.The cables are $50 apiece plus the hubs.Radio Shack has an extender for $100 and then I would need a 50 foot phone line.I'm not sure I want to go that route.
ridgeracer
posted April 04, 2007 04:15 PM
Isn't there a Palm Pilot interface for the power commander
A used palm pilot would be even cheaper than a used laptop
Y2KZX12R
CompetitionCNC.com
posted April 04, 2007 04:31 PM
I havent seen any used palm pilots there.
www.coganfairs.com
Pete, check the schedule...
Y2KZX12R
CompetitionCNC.com
ZXLNT
posted April 05, 2007 02:41 AM
Ridge I think the Palms will let you upload maps, but not edit the fuel or timing values. Still need a laptop for that.
ninja12
posted April 05, 2007 07:34 AM
Buy a usb to serial adapter for Compusa or Bestbuy around $20 if i remember right,
then you new computer will work!
redelk
Please... speak to the hand.
posted April 05, 2007 10:32 AM
You can extend the length of USB by using either hubs or "active" USB extension cables (up to 80').
Belkin 16' extension cables run about $35 each at CompUSA. Sewell carries a "generic" for about $21 each, including shipping.
http://sewelldirect.com/usb2extensioncable.asp
For our 60" plotter at work, I used a Gefen 16' USB active extension and a Belkin Pro Series 16' cable connectted to a Belkin USB Port Replicator that has two Gefen 6' cables going to the computers. Total distance of 38'. I didn't think it would work, but it did.
-Ernest Hemingway
aliveagain
posted April 06, 2007 12:15 PM
I had no serial port on this new computer and no one had active usb extenders.Compusa did send me across the street to a computer repair shop and told me to get a serial pci board.I installed the board,but I'm not getting a connection with the PCUSB.I have a usb mini b terminal going to an A fitting to a serial adapter into the computer.Any computer whizzes out there know what I'm doing wrong?Device manager shows that it has recognized the new serial port.
thekaz
spell chequer is bustimicated
posted April 06, 2007 03:38 PM
My newest laptop doesnt have a serial port so I use a really good USB to Serial adapter at work with a 30FT cable with no issues at all....
It wasnt a cheap Adapter either but works flawlessly. I was forced to so this becuase many of the diesel , blackbox and trans interface programs demanded a usb or on board serial ( dont ask me why they even know the difference )
Pci adapters can be tricky but the USB to Serial is just to darn easy...
redelk
posted April 06, 2007 04:16 PM        Edited By: redelk on 6 Apr 2007 17:34
I'm no computer whiz, but I think "Serial Adapters" with DB9M or DB25M (M-male plug) are used to connect serial devices TO a USB port on a computer. It sounds like your doing it the other way around. Trying to connect a USB device to a 25 pin Parallel or 9 pin Serial port. I don't think that's gonna work.
In other words, if you had an old PCIII that used a serial cable, you might be able use that adapter and connect it to a USB port on your computer (with the right software drivers). If the PCIII is USB, I think it has to be USB cabling from the device to the computer. It could have something to do with serial connections using COM port and/or IRQ addresses and USB connections don't use such. I could be wrong.
Anyway.... without the easy availability of USB active extension cables and not wanting to wait for some to be shipped to you, it seems your only other choice is to buy two DC powered USB hubs and three 15' USB cables (to cover a 45' distance). I'm not so sure a "non-powered" hub would work. By "non-powered", I mean a hub that just uses the power from the USB cable and doesn't have a DC adapter as the hub's power source. It doesn't really matter how many ports are on the hub (2, 4, 7, et.al.), your only interested in using one of them for now.
When getting your USB cables, pay close attention to the plug ends and make sure they will connect from your computer to the hubs and then to the Power Commander. USB cables come in several different plug end configurations. Hubs can run $20~$35 each and the 15' cables will run anywhere from $4 to $35 each.
-Ernest Hemingway
rgeorge
posted April 06, 2007 06:49 PM
Simple solution - Move your computer to the garage!
Permanently
The computer is an important tool for working on a modern engine, just like a wrench or a screwdriver.
Sure, this may make it a little inconvenient to do the other things you usually do with the computer, but youve gotta keep your priorities straight - WORKING ON THE MOTORCYCLE IS OF HIGHEST IMPORTANCE
aliveagain
posted April 07, 2007 04:58 AM
Permanently
You got a point there.That and a couple of garage barbies will complete the package!
posted April 07, 2007 07:46 PM
why not get a laptop ?
for mobility they are the obvious way to go, or am I missing something here?
aliveagain
posted April 09, 2007 05:39 AM
Yes ,you're missing something
ninja12
posted April 09, 2007 01:47 PM
If the new computer has usb, get a usb to serial adapter, I had same problem when my old laptop died and I replaced it with new laptop without serial . It's very simple, I leave the adapter screwed to the serial cable. Run the software , plug in the usb adapter, attach serial cable and program PCIII.
aliveagain
posted April 09, 2007 02:15 PM
Well I finally got a borrowed computer out there and tried to reset the tps. I received a warning that the difference between close and full throttle was insufficient.Repositioned the tps to where on screen, it zeroed out and the same message What are the parameters I'm looking for for open and closed?
tuusinii
posted April 11, 2007 06:13 AM
You mean TPS? At idle (1000RPM) it should be 1,084 -1,086V and go near 5V at WOT.
aliveagain
posted April 11, 2007 06:49 AM
Sorry,I was looking at the signal on the screen.Tps is set at 1.85VDC on the bike.the idle setting on screen would stay at 104%.
tuusinii
posted April 11, 2007 12:12 PM
You mean 1.085V? There is a big difference...
0.2804901599884 seconds processing time
