BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Remove Front Wheel NEW TOPIC NEW POLL POST REPLY
Megabyte
posted April 03, 2007 06:36 AM
Remove Front Wheel
Well, looks like spring has arrived, and I want to install my new rotors. I have the front and rear jacks but the front jack hooks up under the wheel, which makes it impossible to remove the front wheel. Anybody have any tricks or ideas about how to hold the front up in order to remove the wheel? I thought about putting a jack under the engine, but not sure how stable that would be. Also, the manual's instructions say to remove the brake calipers, is this necessary?
thanks,
ZXLNT
posted April 03, 2007 07:04 AM
Can you hang it from the ceiling somehow? And it makes it easier to remove the wheel if at least 1 caliper is off. Definately easier putting back on with the calipers off.
Megabyte
posted April 03, 2007 10:50 AM        Edited By: Megabyte on 3 Apr 2007 11:53
I thought about hanging it from the ceiling. I think I'll look into getting a come along or a pully system to hoist her up.
Thanks for your help!
oof440
posted April 03, 2007 02:42 PM
It will make it alot easier to pull the wheel if you just pull both calipers. It's only 2 bolts per side. I went into a Kawi shop a few years ago and saw where they had a bike jacked up under the header. I've tryed it a couple of times and it seems to work ok. Since then I've just bought a steering stem stand, no worries now.
Megabyte
posted April 03, 2007 03:13 PM
Thanks for the info. I should have bought one of the stands also
If I do this by the #'s,
1) Get the front wheel off the ground
2) Remove both calipers
3) use spark plug socket on big end to (loosen or remove) spindle ?
4) remove pinch bolts on big end (same end I used the spark plug socket)
5) remove wheel
Thanks again
twista
" Get up, and Stay up ! "
posted April 03, 2007 04:24 PM        Edited By: twista on 3 Apr 2007 18:06
get a strong buddy to tilt it on the side stand,, first loosen the caliper bolts and crack the axle leaving the allens on one side tight,, swap them out in 1 minute flat! if ya have an impact pending for the allens on the rotors..
megabyte
posted April 04, 2007 07:39 PM        Edited By: megabyte on 4 Apr 2007 21:44
Success, sort of
Well, I got my new rotors on, but like everything, it didn't go as planned. The spark plug socket fit, but my 1/2 impact wrench couldn't budge the axle. So, I put a breaker bar on it and applied so much torque that the 3/8 socket extention began to twist to the point of breaking. Next, I went to the bike shop looking for a 22mm hex socket, but all they had was one rated @ 90 ft/lbs, and I didn't think it would do the job. So, I looked around town for a 1/2 '' 22 mm hex socket w/o luck. I finally found a 17mm hex socket, and remembered somebody said you could remove the small side w/a 17 mm hex. So, back @ home I tightened the pinch bolts on the big side and loosened the pinch bolts on the left side. I put my new 17 mm hex socket on my impact wrench, and the nut spun right off, and the rest is history, who'd of thought Glad I took the day off.... I appreciate all the help. The idea to suspend the front of my bike from the ceiling worked, and the 17mm hex socket worked, so all in all, I feel pretty good..
ZXLNT
posted April 04, 2007 09:32 PM
Megabyte when you put the front wheel on did you remember to space out that one side at the bottom of the fork leg. Its like 2 or 4mm space between the spacer and the inside of the fork leg. It was in a addendum to the service manual..
megabyte
posted April 04, 2007 09:52 PM        Edited By: megabyte on 4 Apr 2007 23:09
I think it was 1/11 th of an inch. However, I have no idea how I would change the spacing if it was wrong?. I followed the manual's instructions about not tightening the pinch bolts before bouncing the front end several times, not really sure what that accomplished....? The front wheel spun easily, there was no play on the axle, and the Bike rides fine. Removing the calipers did make the job easier. I think everyone who works on bikes should have a good impact wrench. Onward into life. My next project is to replace my rear sprocket and chain. I don't have a chain breaker, or the tool to do the master link, so I may go to the shop for this.
ZXLNT
posted April 09, 2007 02:41 AM
Buy the tool and do it yourself. Its really not that hard. U can use a dremel or grinder with a slitter wheel to cut the old chain off.
Megabyte
posted April 09, 2007 11:58 AM
That would be more satisfying, not to say cheaper...
0.23061990737915 seconds processing time
