mrfast
posted May 28, 2002 02:22 PM
Crank question for Doug
I hope this hasnt already been asked,for us '00 and '01 owners considering a 1361 would it be beneficial to purchase a new "heavy" crank(if feasable),or just modify the existing crank?
posted May 29, 2002 10:03 AM
The cranks are substantially different. It is not specifically a power issue but a power "delivery" issue. The added inertia changes the rev rate and low speed response quite a bit. Also teh added inertia will effect the setup on a drag application as far as handling teh added inertia at the light.
So, it wouldn't be fair to send someone with an '02 anything but an '02 stroker. This means that your core wouldn't replace an '02. For now, you need to supply an '02 crank if you want an '02 stroker.
Doug
