BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Radial Forks? NEW TOPIC NEW POLL POST REPLY
Seth ZX12r UK
posted March 01, 2007 11:30 PM
Radial Forks?
Anyone know if you can upgrade the early lower fork tubes to the radial type?
Are ZX10 forks a straight swop size wise, using a spring upgrade, spindle size etc?
  Ignore this member    Click here to visit Seth ZX12r UK's homepage.
WARBIRD
posted March 02, 2007 08:01 AM
That's a good question. I'd like to know myself..................if the whole fork assembly would fit a 12............a guy could swap wheels also. Hell of a brake and wheel upgrade for the 12 huh?
I'd Rather Be Roadracing.
worm~hole
posted March 02, 2007 08:46 AM
...what's the diff between the radial brakes of the 12R and the 10R?....I was thinking about maybe one day swapping the radial system of the later 12R onto my early non-radial 12R just because is looks sexier and probably works better...
who would do us harm.”
-George Orwell
Seth ZX12r UK
posted March 02, 2007 09:56 AM
What we need to know is diameter of the zx10r forks upper stanchions.
And the axle diameter?
If the axle is the same you could use a 12r or 10r wheel.
You would need longer brake lines cause the radial line coupling is lower.
You'd also need 310mm discs or some 10mm spacers on the caliper mounts.
If the springs are different rates thats easily sorted.
Performance wise you get improvement from less flexing, 4 pads a caliper, better geometery is more efficient.
Impressive
posted March 04, 2007 06:39 PM
This should interest you. I'm going to do the switch, I just bought the main parts.http://zx-12r.org/phpBB2/viewtopic.php?t=45587&postdays=0&postorder=asc&start=0
Seth ZX12r UK
posted March 05, 2007 08:13 AM
Thanks..that looks the dog's...
Impressive
posted April 13, 2007 07:10 PM
I am getting custom spacers made for the 10's swing arm and the 6's pivot bolt and waiting on my upper triple and then reassembling the bike with a new paint job. Amped!!!!
hyper12r
posted October 19, 2007 11:52 AM
http://cgi.ebay.com/ebaymotors/04-05-KAWASAKI-ZX12-FRONT-FORKS-NINJA-ZX12R-SHOCK-MUZZY_W0QQcmdZViewItemQQcategoryZ35592QQihZ001QQitemZ110180869673QQrdZ1QQsspagenameZWDVW
http://cgi.ebay.com/ebaymotors/00-05-Kawasaki-ZX12-ZX12R-Front-Forks-Suspension_W0QQcmdZViewItemQQcategoryZ35592QQihZ006QQitemZ160168773661QQrdZ1QQsspagenameZWDVW
04-06 zx12r front fork at ebay....
0.22189784049988 seconds processing time
