BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Fuel pump? NEW TOPIC NEW POLL POST REPLY
Seth ZX12r UK
posted March 01, 2007 10:27 PM
Fuel pump?
Is it advisable to upgrade the fuel pump, when building a Big'N ?
I know the pumps were upgraded on the B models from the A's, do they have the capacity for a bigbore motor, whats the limit?
  Ignore this member    Click here to visit Seth ZX12r UK's homepage.
sc57
posted March 02, 2007 01:38 AM
dunno whats recommended but we use a bosch unit that pumps through 70+psi, made it very difficult to map at low RPM ( we use it on a Road Race sidecar and if we're on the noise thats not an issue ) but we have 196 rear wheel HP , according to the dyno ,with not much work ( cam timing, slightly different profiles , and inlet port clean up)
sc57
posted March 02, 2007 01:40 AM
Oh and our home built 4 into 1 exhaust with tapered headers ( no one makes them for sidecars )
posted March 02, 2007 02:58 AM        Edited By: entropy on 2 Mar 2007 02:59
Muzzy has a pump which has plenty of capacity for motor upgrades on the A's, dunno anything about the B's.
seth, remind me what you are building???
Seth ZX12r UK
posted March 02, 2007 03:23 AM        Edited By: Seth ZX12r UK on 2 Mar 2007 03:24
A Monster!
Seth ZX12r UK
posted March 02, 2007 03:26 AM
Thats some power from a stockish motor!
What do you put that, down to, your making bigbore power there.
aliveagain
posted March 02, 2007 03:48 AM
save yourself the money and just have some head work done and a piston kit install.
Seth ZX12r UK
posted March 02, 2007 04:42 AM
Piston kit meaning bigbore? or high comp stock?
If thats what you did, what power you making?
hyper12r
posted March 02, 2007 05:43 AM
is it advisable to upgrade to muzzy pump for my stock bore A1(full system,stacks,degree cams)???thanks
Seth ZX12r UK
posted March 02, 2007 09:42 AM        Edited By: Seth ZX12r UK on 2 Mar 2007 09:48
Bosch do some good pumps and valves, 70 psi is mad. 42-46 psi is standard.
Did you need a new regulator?
Do you not get problems with air in the fuel what with the return feed?
Can they be bought online?
How much?
have you got the model no.?
thanks
osti33
posted March 02, 2007 10:52 AM
If you are building a B model 12 the stock pump will support at least 300 horsepower. Any all motor B model bike will be fine with the stock pump.
Seth ZX12r UK
posted March 02, 2007 11:04 AM
Excellent!
Y2KZX12R
CompetitionCNC.com
posted March 02, 2007 11:45 AM
you can use a Walbro gss 342. http://www.bikeland.org/board/viewthread.php?FID=1&TID=20929&pagenumber=2
Y2KZX12R
CompetitionCNC.com
sc57
posted March 02, 2007 12:27 PM
No
No but our tank is lower that the injectors if that makes a difference
How much?
It was on the bike when I got it, so I don't know the price or availability
I'll have a look when I get to the workshop
Note I would not use this set up if I was trying to ride on the road as it is pretty crap at low speed
I intend to fit a SARD regulator to reduce the pressure , but I'll do that when we're on the dyno next so we dont loose any power
Seth ZX12r UK
posted March 03, 2007 07:52 AM
No
How much?
Cheers..
Where do you race your outfit?
sc57
posted March 03, 2007 03:58 PM
Hi we're based in Melbourne Australia , we compete in the Aust Sidecar Champs as well as local club meetings, we get to ride at pretty well all the road race circuits in Aust including Phillip Island
Cheers
Seth ZX12r UK
posted March 03, 2007 04:14 PM
Cheers
Philip Island is a quality track.
WSB Superbikes this weekend you going/been?
0.21537709236145 seconds processing time
