supra5677
posted February 24, 2007 03:12 PM
Y2K peak power estimator
Hey Y2K:
Im putting my cam in this weekend..Can you go into your software and tell me where my peak power will probably be.
The specs on the intake cam are .383 lift and 253 degrees of duration at .050. Lobe Center on the intake 105
Exhaust cam is .342 and 238 degrees of duration at .050. Lobe Center is 103
Rev Limit is 12,240
static compression 12.8 to 1.
thanks,
supra
Y2KZX12R
CompetitionCNC.com
posted February 25, 2007 05:11 AM
Theres so many varriables and unknowns that you have to enter in. Cam specs are just a few and its only a guide to really show trends.
But it should move it up nicely. hopefully it wont table top at 10,500 now.
Y2KZX12R
CompetitionCNC.com
Megabyte
posted February 25, 2007 11:05 AM
What Cam are you installing?
quote]Hey Y2K:
Rev Limit is 12,240
thanks,
supra
supra5677
posted February 25, 2007 01:08 PM
I'm using a Webcam..Intake .383 Lift / 253 duration at .050
park12r
posted February 26, 2007 03:31 AM
Edited By: park12r on 26 Feb 2007 03:33
since you have web intake cam..why not install your stock intake cam on the exhuast side?
supra5677
posted February 26, 2007 10:46 AM
I actually have an extra intake cam also..want to see the results of the intake cam first..
posted February 26, 2007 11:36 AM
quote: since you have web intake cam..why not install your stock intake cam on the exhuast side?
i guess with a little machining it wouldn't be all that hard to mount a cam trigger on an intake cam. But worth it??? I dunno????
