BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Ignition switch... NEW TOPIC NEW POLL POST REPLY
kris_big
posted January 22, 2007 07:35 AM
Ignition switch...
How to remove ignition switch? I mean how to remove, clean and installed the same way, without cutting or damage anything? Is it possible? or I need new bolts, washers etc...?
I found there are two torx bolts that hold ignition switch, is it possible to just unscrew them?
My ignition switch probably is dirty and wet inside after few years of use and a lot of motorcycle clean ups.
When I turn key on, sometimes got something like electrical connection in ignition switch is not in contact and brakes a little.
What about the access to the screws that I need to drill out? Do I need to remove any other parts?
vozizm
Got Nothing Witty To Say
posted January 22, 2007 07:42 AM        Edited By: vozizm on 22 Jan 2007 07:44
get a manual,
or check the fische on ronayers.com
kris_big
posted January 22, 2007 07:47 AM        Edited By: kris_big on 22 Jan 2007 07:48
Manual doesn't say how to remove ignition switch!
This is why I ask someone who do this before?
jus1975
posted January 22, 2007 12:04 PM
I drill and used an easy out and then put some back in .
kris_big
posted January 22, 2007 12:53 PM        Edited By: kris_big on 22 Jan 2007 12:54
jus, how much and how many things I need to remove to have an access to drill out bolts? front fairings etc... ???
12r1
posted January 22, 2007 02:18 PM
Mine screwed out very easily, with a pair of bent -tip needle nose pliers. Try it, you may be as lucky!
12r1
posted January 22, 2007 02:20 PM
Oh, forgot my bike was apart....
They were'nt tight at all, for me. It was a '00, parted out last year.
jus1975
posted January 22, 2007 04:57 PM
I cant remember. Its been awhile and I had the bike totally apart at the time.
kris_big
posted January 23, 2007 01:29 AM
Thanks for Your help. I really don't understand why it happens. Ignition switch loosing electrical connection inside from time to time when I move key to "on" position, but mechanically is still ok.
0.25078105926514 seconds processing time
