beansbaxter
posted May 19, 2002 08:26 PM
How can I adjust my seat height?
2002 ZX-12R...How do I adjust my seat height? I need to bring it lower if at all possible. I loosened the rear dampener as much as possible, but that didnt help much. Any suggestions??
Also...I have read online that the seat height is adjustable using shims. What are shims? Can anyone tell me more about this?
Any help here is greatly appreciated.
Dino
posted May 19, 2002 08:57 PM
Before I answer anything.......are you fishing?
uh oh
zx12richard
The Green Monster..
posted May 19, 2002 10:09 PM
Lowering links,drop the front forks at the tree..... Easy and cheap.... Mine was about 1 1/2 inches too tall for me when I got it.......
beansbaxter
posted May 19, 2002 10:15 PM
Edited By: beansbaxter on 19 May 2002 23:15
No...Im not fishing.
I just bought my new 2002 ZX-12 and it sits too high. I'd like to drop the seat height down some. My toes barely touch the ground, and at stop and go traffic, I would feel more comfortable on it.
It feels fine riding, its just hard to balance/control at stand stills.
zx12richard
The Green Monster..
posted May 19, 2002 10:24 PM
Its basically loosening the bolts on the fork tubes and letting them slide down a little... Make sure its evenly but should be no problems... Mines down between 3/4 to and inch. It was too tall for me also..... Some may argue and some will agree but to me I think its easier to turn into turns and handles better.... These are my opinions others will differ.... Disclaimer huh.....LOL I'm glad I did it and would do it again......
kevvnn
n/a
posted May 19, 2002 11:46 PM
raise my seat height on my 02 12r
how do i raise the seat height ? so im more over the front forks. aka like a race bikes more leant forward. ? cheers big ears. kev uk. (north wales uk )
PIGSEARS( BANGOR AYE )
beansbaxter
posted May 20, 2002 10:39 AM
My dealer strongly recommended that I dont lower the front forks, because it messes with the turning and would void my warranty. I'm going to call Kawasaki and ask them, since they do say the seat height is adjustable.
beansbaxter
posted May 20, 2002 10:50 AM
Just got off the phone with Kawasaki...
The seat height is adjustable, by adding shims you can raise it but it comes from the factory at the lowest level.
His take on dropping the forks...it does not void the bike's warranty, and while it will help a little, it does effect the steering aspect of the bike.
Yet, he did recommend that I do not lower the forks and either get a smaller seat (sigh) or purchase bigger boots (LOL).
On a last note, he did recommend that I ride the bike more to allow it to settle. He said it will drop a little, but not much. I think I'll do just that and ride it more. Worst case scenario...I'll drop the forks though.
MikeM
posted May 20, 2002 11:44 AM
Lowered seat height
Baxter. Do you mean seat height or ride height? Seat height will mean buying or modifiying the seat squab but will have little effect on handling other than taking some weight off the front end, remedied by pulling the fork legs up through the yokes (if you are going to do this make sure that under full suspension compression the front wheel does not come into contact with anything else, otherwise you will found ou how well you can fly!!!) If you mean lowering the rear ride height to make the whole of the rear of the bike lower, and in turn slackening the head angle=slowing the intial turn in of the bike, then this might be the way to go. Remove tank cover, seat unit and seat squab plus whatever else you need to remove to hinge the tank up. Under the seat area is a large nut with a threaded rod with a split pin in it protruding through the middle. I'm not 100% definite on a zx12, but on a zx7 this is the rear ride height adjuster for the rear shock top clevis mount, I've looked at my 12 and it appears to be the same. The "nut" is part of a captive system that by turning anti-clockwise (undoing) raises the rear of the bike, and clockwise lowers. I suggest you take a measurement with the bike unladen and on a paddock stand as it is now, and then one turn at a time re-measure and see what effect it has by altering the nut.Go slowly and before riding the bike me 100% certain that nothing bottoms out!
