BIKELAND > FORUMS > ZX12R ZONE.com > Thread: First drag clutch problem NEW TOPIC NEW POLL POST REPLY
fast
posted May 19, 2002 07:31 AM
I have some whasher under springs but clutch
still slip.Made 6 run only one it slip to fell it on rpm
all other didnt slip as mutch but can fell there
is no pep when shifting!Is it just dry or need
stronger springs?Whats the best clutch set up?
Muzzys thicker plates do they work good?
Do the zx6 springs are the best?
Need help anybody have thikness of muzzy plates?
Thanks!
9.29@151
zx12richard
The Green Monster..
posted May 19, 2002 08:06 AM
I would definitly get 6r springs..... I am ordering the entire Muzzy clutch setup tomorrow.... My steels warped I believe... But no clutch slipage at all. I have the 6r springs in... When I put the Muzzy setup in I am still going to use the 6r springs... I heard the muzzy setup was 3 stock 12 springs and 3 stiffer springs... Don't know if thats true or not..... I'm going 6r...........
VINCE12
Designated Drinker.
posted May 19, 2002 08:27 AM
I have Muzzys clutch hub and basket with #ZX12001 80lbs. springs from Schnitz!!!!I installed all six springs and my clutch works perfect so far!!!
2012 Metallic Spark Black ZX14R
BA
posted May 19, 2002 06:41 PM
FAST: Once your clutch slips, and then does it a few more times,...the fiber plates will generally need to be replaced. They won't get better! The slippage causes them to get a slightly "glazed" look to them.
(we all wonder if a light sanding would fix that, but I don't know anyone who has tried)
If your bike is a 2000 or 2001, you could have the dealer modify the clutch for more oil flow,....that is what the Muzzy kit does basically.
And, yes, the Muzzy kit is 3 stock springs and 3 'muzzy' springs.
In that kit, Muzzy's 'thicker' steel plates are just the 2.0mm stock Kawasaki plates. A stock clutch can have (I think) 1.4mm and 1.6mm and 2.0mm to get the desired stack height. Muzzy just TAKES OUT one steel and one fiber plate, and then makes all the remaining steels 2.0mm.
That plus the extra oil flow works to a degree, but it still isn't a great drag racing clutch setup.
Get this, I was looking online for a friend and noticed that the ZX-9R uses 2.0, 2.3 and 2.6mm steel plates!!! WTF! I'd love to have that...
posted May 20, 2002 07:20 AM
definatly the Muzzy set up is the best way to go, the hub and billet basket!! it has almost doubled my clutch life and Im a serial killer on clutches....
Mad Mike
0.23764300346375 seconds processing time
