BIKELAND > FORUMS > ZX12R ZONE.com > Thread: exhaust lobe center NEW TOPIC NEW POLL POST REPLY
supra5677
posted December 22, 2006 08:39 PM
exhaust lobe center
Is there enough piston valve clearance to run 107 degrees lobe center on the
exhaust cam? thanks..
supra
osti33
posted December 22, 2006 08:45 PM        Edited By: osti33 on 22 Dec 2006 20:46
Stock cam and stock piston?? Stock valves? Stock piston to head clearance?
Need a little more info...
supra5677
posted December 22, 2006 11:15 PM
stock everything except thin head gasket...
posted December 23, 2006 03:49 AM
info:
not stock pistons but i run 107/110 on Muzzy cams.
00 OEM exh cam has .342" lift
Muzzy exh cam has .390" lift
i'd guess that you could run exh LC = 107 with ease, but might be good to measure it just to be sure.
supra5677
posted December 23, 2006 12:15 PM
at what rpm did you make your power peak? I'm aiming for 11,600 or more.
posted December 23, 2006 05:29 PM
about flat from 10500 up
0.27954316139221 seconds processing time
