BIKELAND > FORUMS > ZX12R ZONE.com > Thread: new gearing speed parts NEW TOPIC NEW POLL POST REPLY
BEAR
posted May 17, 2002 01:18 AM        Edited By: BEAR on 17 May 2002 02:20
New gearing and speed parts
NEW GEARING
Like the busa gears i have found the cure,billet gear sets include higher ratio 5th gear and 6th gear that match pefect with your exsisting transmission. The trick part is that they have 8% higher gear ratio which allows you to run bigger sprockets you need to get of the line and not run out of revs at the end of the line.I never spoke about these gears as we were testing them and found that they work well,THE ONLY PROBLEM IS THAT IT ONLY WORK WITH +200hp BIKES.(BIG BORE, NOS and Turbo)
GEAR set $560.00
Velocity stacks $200.00 per set
Will take orders now and will be keeping them in stock.
1 X STD set 46mm = $200.00
1 X B/B set 48mm = $210.00
10 X STD set's 46mm = $ 1790.00
10 X B/B set's $48mm = $ 1890.00
These price's include normal shipping of 5-9 days to the USA
If by UPS additional cost is $19.00
To place an order You can pay with PAYPAL or wire transver in to my account
Place orders on BEAR@YEBO.CO.ZA
http://www.PAYPAL.COM
7.56@195 Worldfinals 2004
7.43@ 194 Britol 2008
  Ignore this member    Click here to visit BEAR's homepage.
VINCE12
Designated Drinker.
posted May 19, 2002 09:21 AM        Edited By: VINCE12 on 19 May 2002 10:22
Hey BEAR,,,,,I just sent payment with paypal for a set of stacks plus UPS shipping!!!
Planed on getting them way back but my funds ran dry,better late than never!!!
2012 Metallic Spark Black ZX14R
BEAR
posted May 19, 2002 11:47 PM
Stack's on the way,will leave today
VINCE12
Designated Drinker.
posted May 22, 2002 05:56 PM
Hey Bear,I got the stacks today and they look great but they say 48 on the inside???I need a set of 46mm stacks!!
BEAR
posted May 23, 2002 12:42 AM
Stack's set up
No they would have been modified to 48mm but as you wanted UPS that was the last set ,put them in an you will see they are std
VINCE12
Designated Drinker.
posted May 23, 2002 02:42 AM
LOL,Thanks Bear!!!
Also like to thank you for the fast shipping,and the stacks are works of art!!!!!Too bad there not visible when installed
Ozzy
need guberment cheese
posted May 23, 2002 05:06 AM
A Really Dumb Question ( or 2)
I don't understand why the new 8% overdrive gears wont work in a stock engine? Are you referring to not having the hp to pull the higher ratio? I am not interested in top end speeds. I want to drop the rpm's at hiway speeds in 6th gear.
Can just the 6th gear be changed?
Are these gears as durable ( for wear) as the oem gears?
Can you make a 1st gear set that is 6% LOWER? Be just like putting on a 17t countershaft sprocket in first. A lot better for around town riding.
For those of us that sport tour our 12R's, a lower 1st and a higher 6th would make an incredible gear box ratio set.
Has anyone noticed that the '00 sales brochure shows the gearbox on the 12R as close ratio, and for the '02 they call it wide ratio? Yet all the ratios are the same in the parts manual! The wonders of advertizing,LOL.
kcadby
posted May 23, 2002 06:50 PM
Ozz...If you only lower 1st then...it would be too big a spread to 2nd...IMHO...
I think it WOULD work well in bikes that are geared lower for "drag racing" but still go good on the highway
BEAR
posted May 24, 2002 03:49 AM
Gearing
I run a 17 49 and I can run 341kph at top end this means that it is good for drags and runs top end as well
0.22857093811035 seconds processing time
