BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 105/105 vs 105/100 cam timing NEW TOPIC NEW POLL POST REPLY
ninja12
posted November 15, 2006 08:29 PM
Those are the two numbers i hear most on the 12.
How does the 105/105 change the power delivery compared to 105/100.
posted November 16, 2006 12:48 PM
Gerard,
I have some info but no straight apples-to-apples comparison; fuel changes, cam type changes, cam CL changes, 1361/1375/1427 changes, weather changes.
Doubt the info would be useful to you, but if you wanna look at a big spreadsheet , you KNOW I will send it to you.
ninja12
posted November 16, 2006 10:53 PM        Edited By: ninja12 on 16 Nov 2006 22:54
I'll take your word for it.
Can you give me the short answer,
raise or lower the peak hp?
supra5677
posted November 17, 2006 08:04 AM
short answer is closer lobe centers give your more peak power and move the power band up. So 105/105 keeps the exhaust cam open a litte bit longer for more rpm breathing.
The exhaust side of the zx12r has some flow problems due to the desing angle of the exhaust valve to the header. 105/100 will give more torque than 105/105. Im running 105/103 and really like it. But actually you might find better luck with 106/101 as the engine responds more to the intake cam than the exhaust cam.
supra
tcchin
posted November 17, 2006 04:56 PM
A smaller LC number on the exhaust side means more retarded exhaust cam timing (and more overlap), whereas the opposite is true for the intake side.
psycho1122
posted November 18, 2006 08:02 AM
For example; I run 105.5 in. and 99.5 ex. on my 2000 1270.
I get 98 ft. lbs. of Torque by 3,800 rpm, 102 ft. lbs. by 5,000 and a Torque peak of 111 ft. lbs. by 7,600 rpm.
190.3 h.p. comes in as soon as 10,000 and holds it to rev limit.
jessz1
Half the wheels, twice the fun
In all honesty there will be very little seat of the pants difference between the two. I degreed mine at 105/100 I think.... it has been so long ago. I gained no horsepower but it did flatten the area under the curve a bit and was worth a little over one mph at the strip.
These are just my personal conclusions. No real scientific facts....
I'm never satisfied.
  Ignore this member    Click here to send jessz1 an AIM message.
0.40850806236267 seconds processing time
