BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Anyone Ever have a Broken Valve SPring or Cams Shift Time? NEW TOPIC NEW POLL POST REPLY
posted October 22, 2006 04:58 PM
I plan to check the Spring tension on the intakes and see if I can check the cam timing in the frame.
Then back together and change the ECU then bypass the Schnitz Timing retard and then the PC3 to see if any of this makes a difference!.
The Bike Idles and starts fine and revs to 6 to 7,000 before I can hear a very slight miss which stays there until the redline!
0.26362895965576 seconds processing time
