BIKELAND > FORUMS > ZX12R ZONE.com > Thread: black plugs NEW TOPIC NEW POLL POST REPLY
aliveagain
posted October 02, 2006 07:33 PM
black plugs
I finally started the bike and rode for about a 30 mile ride.When I checked the plugs,they were black and wet.This all seemed to happen after I changed out the connecter from the alternator.Redid the splices to ensure good continuity.New plugs,changed out the coils and still its not getting a good spark.Any suggestions?
zx12mark
posted October 02, 2006 08:01 PM        Edited By: zx12mark on 2 Oct 2006 21:02
. are all the plugs black and wet.. if you have a pc or yosh box ,go back to stock to confirm it's not bad.dose the end of the exhaust look black.it should look light to dark brown.not wet black.
if you have a pc reload the map.i think they need to be refreshed every 3 to 6 months anyway.
aliveagain
posted October 03, 2006 02:49 AM
Now all along,I'm thinking it is a spark problem but you're saying map?I only pulled one plug because right before I took the motor apart again,they were all black ,so I knew the problem was still there.
BROOKLYNNYZX12
posted October 03, 2006 01:38 PM
Did you accidently cross the sensor plugs around?I can't remember which 2 have the same plug?
flite leader
posted October 03, 2006 04:24 PM
that much fuel in the engine cant be.... & never is good
there was a problem delineated a few years ago
with a sensor that could be connected in reverse
no less you only need the stock map
while the engine is new
& you are breaking it in
any other map is pointless & useless
try NOT to get caught up in the anxiety of
new parts.....!!! new engine.......!!!!!! & possibly unreal expectations
check.....double check & check again
good deliberate problem solving techniques is what you need now
i suspect is a nickle or dime problem
that could cost you if you dont find it......................& Soon !!!!
take those cover plates off the air box(safety glasses & extinguisher at the ready)
see if you can detect whats happening
try not running the engine any more than necessary
road tests are out until youi find your problem
good luck
bend your mind.....
or break your ass...!!
aliveagain
posted October 03, 2006 05:54 PM
The tuner just told me I have to put 50 miles on it for the new rings to seat before it goes on the dyno.I knocked it down 2 bars on each button on the usb.
I already had to learn about the tps switch and map sensor and double checked the manual while assembly.With 17/52 sprocket combo,I was running 5 grand on the highway to go even with traffic.I dropped the bike off tonight and they'll check the map tomorrow and also sync the tb's.This was doing the same thing before I blew the head gasket.At the track,once I did a burnout it would clear up going down the track.I didn't check any of the ecu outputs and was running out of time to say yea or nae on MIR.
posted October 04, 2006 03:25 AM
AA
make double-damn sure yr airbox temp sensor is plugged in and functional. I didn't plug it in once and man o man it ran rich!!!! ECU prolly thought it was 20 below zero
psycho1122
posted October 04, 2006 08:35 AM
enrtopy;
No FI light on that one?? ECU did not care that that sensor was open?!?
posted October 04, 2006 09:19 AM
FI lite was probably on, and i just didn't see it
The bike was on the stand and I started it with the airbox covers off. Ran like shit with a world of black smoke. Scared the shit outa me.
(another lesson learned )
aliveagain
posted October 04, 2006 11:05 AM
Interesting thought if that was true,what would happen if NO2 was sprayed directly on it.I usually don't disconnect that sensor anyways.
aliveagain
posted October 04, 2006 11:15 AM
193hp/108tq here we come MIR!
shiphteey
posted October 04, 2006 12:00 PM
When are you running @ MIR?
aliveagain
posted October 04, 2006 04:22 PM
I just called, all sold out.Jason said I could run Friday night so I have to decide if I want to stay that late.It's a 6 hour ride.
Turns out the map was all fu.1-5 thou,it was at 18/1 f/a.
0.27109599113464 seconds processing time
