BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 010 /65 tire.. NEW TOPIC NEW POLL POST REPLY
GOZR
GOZR
posted April 28, 2002 06:14 PM
010 /65 tire..
Who tried this front tire the 010 /65 instead of the 70.
I'm getting a 190/55 at the rear very soon..
Advis? opinion?
-G
redelk
Please... speak to the hand.
posted April 28, 2002 09:34 PM
a 190/55?
Do you mean a 190/50 or a 180/55? I didn't know there was a 190/55. Of course, I ain't the brightest bulb on the shelf either! I run a 120/65 with a 180/55. I like the quicker response, but I still haven't found the best suspension settings for that combination. You will have to tweak your suspension to compensate and take full advantage of the 120/65. If you've moved your forks up in the clamp, you might want to move them back down before you take your sag measurements.
I will be running a 120/70 when I put the Rennsports on for the Gap trip. Metzeler doesn't make a 120/65 in the Rennsport ("street" tire). Just a 102/70, 120/60 and a 110/70. I'm not expecting them to last as long as the Pilots, so I'll either begoing back to the Pilots of trying out some 010s after the trip.
-Ernest Hemingway
GOZR
GOZR
posted April 28, 2002 11:07 PM
lol my mistake i meant 190/50
-G
silver01bullit
on here too much
posted April 29, 2002 03:28 AM
Rennsports are being made in 190/55 now, in the standard, soft and super soft compounds.
  Ignore this member    Click here to send silver01bullit an AIM message.
GOZR
GOZR
posted April 30, 2002 10:03 PM        Edited By: GOZR on 30 Apr 2002 23:05
089311 180/55ZR17 17 BT010R BW TL - 73W Z 24.7 7.3 7 (5.50)5.50-6.00 805 42
105376 180/55ZR17 17 BT010R BW TL F 73W Z 24.7 7.2 7 (5.50)5.50-6.00 805 42 (CBR600 F4i 2001-2002 )
For the rear what differences on those 2 180/55
103349 190/50ZR17 17 BT010R BW TL E 73W Z 24.8 7.5 8 (6.00)5.50-6.00 805 42 GSXR1000 2001-2002
089338 190/50ZR17 17 BT010R BW TL - 73W Z 24.7 7.5 7 (6.00)5.50-6.00 805 42
089532 190/50ZR17 17 BT010R BW TL G 73W Z 24.6 7.4 8 (6.00)5.50-6.00 805 42 CBR929RR 2000-2001
and those 190??
-G
redelk
posted April 30, 2002 11:17 PM        Edited By: redelk on 1 May 2002 00:18
089532 - Bridgestone Article Number
190/50ZR-17
190
-Section Width (in mm)
50 - Aspect Ratio (% of Section Width)
Z - Speed Rating (149+ MPH)
R - Radial
17 - Rim Size
17 - Rim Size
BT010 - Tire Model
R - Radial
BW - Black Wall (no white letters)
TL - Tubeless
G - Original Equipment Code ('00-'01 CBR929RR)
73W - Load Rating
Z - Speed Rating
24.6 - Overall Diameter (in inches)
7.4 - Tread width (in inches)
8 - Tread Depth ( in 1/32")
(6.00) - Recommended Rim Width
5.50-6.00 - Acceptable Rim Width
805 - Max. Load (in lbs.)
42 - Max. PSI
CBR929RR 2000-2001 - Specific brand and model of bike the tire was designed and manufactured for.
Hope this helps.
-Ernest Hemingway
zx1012r
posted May 01, 2002 02:29 AM
120/65zr17 front
Last fall I put 010's on before a Blue Ridge trip. Did not change anything else on the suspension. In some really harry corkscrew backroads in Virginia I was scraping the bottom of my fairings. I needed to raise the ride height some to stop this. It did turn in slightly quicker with the 65 profile but not a huge difference. I'll be going back to the 70 when these tires are shot.
0.39722514152527 seconds processing time
