BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Gas Tank Removal NEW TOPIC NEW POLL POST REPLY
bluemoss
posted August 04, 2006 07:37 AM
Gas Tank Removal
Has anyone every removed there gas tank off a 02 ZX-12r, if so, how? From relieving the fuel pressure prior to getting the fuel out to taking the tank off.
droid
posted August 04, 2006 02:33 PM
If its the same as an 01 just lift the tank on the hinge put some absorbent material under the supply line and gently let the fuel run till pressure subsides, remove the hinge bolt. Simple as!
aliveagain
posted August 04, 2006 05:30 PM
while off,paint it black instead of that rediculous stock color,to match the frame.
gebla
posted August 05, 2006 12:28 AM
the only problem might be the connectors underneath the tank. You have the insert a small screw driver to press the "lock" of the connectors. It took me sometime to find out how to disconnect these connectors.
bluemoss
posted August 07, 2006 07:34 AM
Yep, planning on painting it black. Yeah I saw those connectors underneath the gas tank. Thanks for the insight guys!!!
0.23806500434875 seconds processing time
