BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Aux power locations? + Hi from newguy NEW TOPIC NEW POLL POST REPLY
jse20
posted April 24, 2002 05:55 PM
I am mounting radar on my ZX-12r and was considering the addition of a GPS unit for longer trips. (Escort 8500 with the hard wire kit and a Garmin V)
Anyone want to share their power routing? I ran two wires directly from the battery out the side and rear along with the existing wires. Then up the back side of the tank over the airbox to where the wires make a Y. I think I can reasonably use that as a main aux power supply.
Anyone else done this? Suggestions?
(This is the part where I kiss ass to get good answers and not get flammed)
This board seems really great and everyone is so nice and knowledgable. I hope I get the chance to meet some of you this summer. I would join you all at the Gap but I already have a trips planned for the end of May and mid September.
Just got my 12r and am enjoying the personalization process. I removed all the decals and have a very expensive list of parts I am hiding from my wife.
See ya
  Ignore this member    Click here to send jse20 an ICQ message. Click here to add 1 to your ICQ list.
Dino
posted April 24, 2002 06:31 PM
welcome! It sounds like yer' doin' it right so far,HOWEVER,...my wife says "what's the point,you always get busted anyway"...... (she gave up on bike stuff a long,long time ago!!
TeamSpeed
posted April 24, 2002 08:02 PM
If you pull off the rubber fuse box cover, the blue/white wire on the right harness (I think it is the last left wire on the bottom set of wires on this harness) is marked as the switched accessory line. You could have tapped this wire, and ground, and your detector would go on when you turned on the key.
This is the line I tapped for my A/F meter and heated O2.
frEEk
posted April 24, 2002 10:53 PM
one of the fuses in the fuse box is unused. i used that one for my radar power supply. i believe it is always on, if memory serves me correctly. i like using that lead because it keeps things looking fairly stock; no extra leads to track down etc
jse20
posted April 25, 2002 03:06 AM
Anyone have a wiring diagram they can post? I didnt want to tap into anything without knowing what was what. Thats why I went to the battery.
hotrodninja
posted April 25, 2002 06:24 AM
Unless you have a 2002, looks like they used the accessory fuse for the second cooling fan.
Be consistent, win money.
jse20
posted April 25, 2002 09:16 AM
Year
Yes I do have a 2002. I just stopped home for lunch and have not had a chance to look.
hotrodninja
posted April 26, 2002 04:39 AM
You could wire it in with the horn circuit, it has a 10A fuse.
0.25199198722839 seconds processing time
