BIKELAND > FORUMS > ZX12R ZONE.com > Thread: unbalanced wheels NEW TOPIC NEW POLL POST REPLY
frEEk
posted July 10, 2006 03:18 PM
unbalanced wheels
anyone know if a bike is reasonably ridable with the balancing weights taken off the wheels? i don't mean canyon carving, just a highway drone for a hundred miles, at like 50mph. obviously it will depend on the size of the weights. think a farily standard setup.
thx in advance
MAXIMUS
posted July 10, 2006 03:33 PM
just like a car you might get a vibration.
canadamaxxer
posted July 10, 2006 03:44 PM
Bike wheels are not nearly as prone to vibration as car wheels. I have run a rear tire that I mounted and never even bothered to balance....and you could barely tell......even up in the really big numbers.
The front tire has the potential to be more dangerous when out-of-balance than the rear, but has less rotating mass, so even that probably won't shake or shimmy at the speeds you are talking about.
frEEk
posted July 10, 2006 10:59 PM
thx CM. i took the plunge, so hope youre experience holds up in my case. i can always put one of the weights back on if it turns out to be intolerable to the dealer.
tuusinii
posted July 17, 2006 03:12 AM
Why?
frEEk
posted July 17, 2006 07:22 AM
painting the wheel and it was 200kms to my dealer. it ran fine. dont notice the unbalancing at all at least up to 100kph
posted July 17, 2006 08:54 AM
Remove the calipers and the spacers and slide the axle out until the seals do not touch the axle and spin the wheel gently and mark the bottom where it stops. push the wheel forward and see if it stops at the same place. Push it backward and see if the same thing happens. then using Tape a weight pit on an ounce 180 Degrees opposite that and see if the wheel can find the same place to stop. Add or subtract weight until you can push or pull the wheel from 4 different places 4 times and it never stop in the same place. It will be balanced (How we did in the Old days. the only thing hurting this is the bearing seals!
frEEk
posted July 30, 2006 09:43 AM
can't say i noticed any significant vibrations on the whole trip (up to 100mph), so i guess it weren't unbalanced much. i may just try that method vince, thx.
0.23402500152588 seconds processing time
