BIKELAND > FORUMS > ZX12R ZONE.com > Thread: removing the secondary throttle bodies on the 12r.... NEW TOPIC NEW POLL POST REPLY
navpreet318
one crazy 12
posted June 23, 2006 11:07 PM
well guys as you all have seen it...removing the secondary throttle plates has unleashed a lot of power to the 14....
can this be done on the 04-05 12r's as well....there are secondary throttle plates here....all we need is someone to remove and get a dyno.....
i removed them....well the smothness of the bike is gone but the power has increased...like the power 4000rpm upwards has really increased....now what i'm thinkin is making new plates....a little modified....like either smaller in dia or maybe a slot cutted into them....so that the mixture doesn't get overly lean....
what do you guys suggest.....
2005 ZX-12R,Arata Full Ti, PC3,Gillis
Rearsets,Muzzy Velocity Stacks,BMC
Race filters.One Crazy 12
ninja12
posted June 25, 2006 04:48 PM
Bet that will be the answer when the 14 guys get to the end of this.
I suggested drilling the secondary flies, which will result in the same effect as smaller flies.
some testing will be needed to come up with the right size hole or replacement flies to make it work.
ninja12
posted June 25, 2006 04:50 PM        Edited By: ninja12 on 25 Jun 2006 17:51
so good i said it twice.
0.22347211837769 seconds processing time
