BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 12r idle NEW TOPIC NEW POLL POST REPLY
GOZR
GOZR
posted October 26, 2001 05:58 PM
12r idle
The idle goes up and down ...why that on the 12R? it is not regular.. it doesn't do:
VROOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOMM
it does:
VROUMMMMMMMMMMmmm...VrooUMMmmmmmmmmmmmmmmmmm...VrooouMMMnnnn!!
-G
ZXtra
posted October 26, 2001 06:08 PM
Re: idle
GOZR...ZX12R has wild cams from the factory. It will idle OK with stock exhaust. Aftermarket pipes will often cause "idle hunt"? -ZXtra
ZX12ZX11
posted October 26, 2001 09:57 PM
Is idles like shit with an aftermarket exhaust, and even worse at higher altitudes until the ECU has been replaced with the high alt. ECU. But it kinda sound cool, and gets attention at stop lights when people look at the bike and it has the loping idle, the light turns green and it's off like a bat out of hell. Then people know why the idle is like that.
harryzx-12
posted October 26, 2001 11:53 PM
It idles pretty good if you have an Akropovic exhaust on it.That's just one of the reasons I went with the Akro.
Laref_jm
posted October 27, 2001 03:26 AM        Edited By: Laref_jm on 27 Oct 2001 04:27
Sorry Harry,
idle is not good with an akro too..idle waving between 100-200 rpm.
i've the titanium akro pipe, tmh filters, kleen air removed, not any pc3.
the idle hunt is still ALIVE...
question is the pc3 solved this problem, i wonder ??? either you're very lucky harry
Y2KZX12R
CompetitionCNC.com
posted October 27, 2001 05:04 AM
idle hunt
Zxtra hit the nail on the head... its the duration and overlap of the cams. Its the nature of the beast.
Its not a bad thing. If you had cams that idled like a cbr600 F3 then you would loose many HP.
When someone that knows anything at all about high performance engines hears the rumpity rump idle at a stop light they know whats up.
People pay big dollars to get gsxr1100's to make 180hp and have an idle like that. Enjoy what the factory gave us!
Y2KZX12R
CompetitionCNC.com
silver01bullit
on here too much
posted October 27, 2001 05:19 AM
Akro here, no probs with idle, it's a bitch to get started though, I really need a pcIIIr
  Ignore this member    Click here to send silver01bullit an AIM message.
GOZR
GOZR
posted October 27, 2001 09:46 PM
Yes hahahahaha!!
I have a Mussy titanium on it ....great low sound ..
I have also a Gixxer 1100 1987 with Mussy and i have the same thing going on, also on the gixxer i have flat side 40 mn carbs so at idle you can hear what is happening in the heads( sound like a dragster.
I love both...
My baby monster gixxer
Almost finish..
My baby 12
-G
hondo
posted October 28, 2001 03:00 AM
With a D&D slip-on before the potentiometer and TPS mods my 12 had a really nasty sounding idle lope of 50-100 RPM. With both of the above modifications and car air filters, not the Dodge truck K&N's, my 12 ran really well and I could tune out the idle lope with the potentiometer at 490 ohm's. The problem was a slow off idle throttle response. Very sluggish, hiccup, hesitation, you put your favorite word here, untill 3500-4000RPM then it seemed to catch its breath and hang on tight. Second gear power wheelies any time I dialed in full throttle and the RPM's hit 7500 or so. Now with the Yosh EMS and 2 degree timing map no hesitation to blips of the throttle, still has a 50 RPM lope below 1100 RPM. I like!
Tearinitup
VP Code Monkey
posted October 29, 2001 08:41 AM
A little fuel
A little fuel at idle can help smooth out the situation a little. Careful though too much fuel will make the bitch toooo rich during warmup.
Laref_jm
posted October 31, 2001 09:24 AM
Hi Tear,
like WE discuss about it with y2k, the bike seems to be already a little rich even at idle & at stock setting values...i've seen the little black cloud under hard acceleration from idle to 4-5 k while playing with the tps..try other values from 1.084 to 1.15 Vdc to smooth the lope.
even at 1.09 vdc it seems to be too rich...
i've all mods, akro, no pc3, kleen removed, advance
+ 3 mm..
i guess it'll worth to let it at stock values...
your opinion ???
Thx..
KirksterZX-12R
posted October 31, 2001 09:34 AM
If you want your idle surging to almost disappear after tweaking your PC3R, turn your idle adjustment screw in until you're turning 1400-1500 rpm. I have mine set that way and I have no surging.
Tearinitup
VP Code Monkey
posted October 31, 2001 11:23 AM        Edited By: Tearinitup on 31 Oct 2001 11:26
On my 12 actual idle is VERY different than hard accel in the low rpms. Idle (0% throttle 800-1300 rpms) is very very lean on my bike. Adding about 12%-15% more fuel in the upper left corner of the map saved me. It also brought my idle up to about 1300 where it likes to be. Hard accel is a different story completely. Also. You should note that if you richen up your idle tooooooo much then cold start will to be toooo rich and it will not like to run when cold idling, keep that in mind when playing with idle.
L_jm: I would say try to get your hands on a PCIII (not the r version if you don't want to play with the advance) and you will not be disappointed as long as you don't pinch your wires in your tank.
Laref_jm
posted October 31, 2001 11:29 AM        Edited By: Laref_jm on 31 Oct 2001 11:31
Tear, I haven't the pc3...on my bike
my question is : is the stock bike is already rich at stock settings like y2k said...????
while playing with the tps...i found this statments..in my previous post...
some dealers in france said, this bike is very poor at stock settings & others said no..
i want to know...
thx
0.24244999885559 seconds processing time
