BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Fairings and forks?? NEW TOPIC NEW POLL POST REPLY
wylde
posted June 12, 2006 03:34 PM
if by some chance i find out my forks are bent,, ( 00 Model ),, are they interchangeable with 02 and up,, and if not can the 02 be made to work,,and what would be needed,, also the same question for the plastic,, what is needed to make 02 and up plastic work on the 00,, is it just the stay bracket,,just asking,, cause looking through ebay,, and there seems to be alot of front end stuff and body work for the 02 and up stuff..
There you go again,,NOT being aware of yourself !
osti33
posted June 12, 2006 05:49 PM
Forks will interchange no problem.
countersteer
Didn't read the owners manual
posted June 12, 2006 06:43 PM
indeed. but be sure to get fork lowers that arent a nasty color. the later model zx-12s had nicer fork lowers i think?
Scott
Long Island, New York
2006 ZX-14, 2003 ZX-12R
wylde
posted June 12, 2006 06:45 PM
dont know why but i though i read somewhere that the trees where different,,thus requiring year specific application,, guess im gonna need to slack off on the percocets..
thanx guys
zxlnt
posted June 12, 2006 10:04 PM
Make sure if you switch triple clamps that you get a matching pair. Can't use 01 upper and 00 lower or vice versa. I dont remember if steering bearings are same between model years. Forks should interchange though.... Up until they went with radial brakes, and even then would interchange but would have to use radial brake set up..
wylde
posted June 13, 2006 10:00 AM
OK so the forks work no matter what,, just have to make sure i have a matched set of trees correct??
zxlnt
posted June 13, 2006 10:37 AM
Yes, only thing I am not positive about is the bearing size between the A and B models...
wylde
posted June 13, 2006 12:04 PM
10-4 thanx
0.33409094810486 seconds processing time
