BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Lowering links on a 2002 NEW TOPIC NEW POLL POST REPLY
hotrodninja
posted April 18, 2002 04:42 AM
Well wouldn't you know it, the rear links are changed too. If you used stock length 00 links, the rear would be up higher than it already is. I got the new Muzzy three hole links, and the middle positiion lowers the bike just a bit (which goes great with my lowered fork in the tree) When I drop to the low hole, it should be about right. The old muzzy links on the 00 made it a bit too low for my 200lb ass. Can't wait to hit the strip!
Be consistent, win money.
SpencerCyclecom
posted April 18, 2002 09:29 PM        Edited By: SpencerCyclecom on 18 Apr 2002 22:30
2002 Lowering links
We will have these as of MONDAY.
The 2002 ZX12R does take longer lowering links.
If you or anybody want s a set--we have them
3 hole adjustable
you can check them out by clicking on our banner ad or going to
www.spencercycle.com
DOug
SpencerCycle.com
1-800-510-1945
Doug Ray
SpencerCycle.com
SpencerCycle Center Inc.
Spencer Performance Group Inc.
Toll Free 1-800-510-1945 ext #10
International 1-800-510-1945 ext #11
Local/Tech 1-704-642-0987 ext #12
Fax 1-704-642-0987
djones
posted April 19, 2002 05:55 AM
Question about Lowering Links...
On this topic of lowering links. I got my Muzzy's in the other day and put them on but I need some fog cleared out. How come they are longer that stock but that actually lowers the bike?
I also got my kill switch and Shif tlight installed and I will try to post and image.
DJ JONES
Persimmion Red ZX-12R
Humble, Texas
http://www.texas-offroad.com
  Ignore this member    Click here to visit djones's homepage. Click here to send djones an AIM message.
TeamSpeed
posted April 19, 2002 07:18 AM
Susp. Geometry
When you lower the bike, you are basically allowing the shock/spring combo drop farther thru the bike, allowing it to sag a bit with the weight of the bike pushing it down. This makes the distance from the bottom of the suspension to the swingarm farther. A longer dogbone will lock this "sag distance" into place. A short dogbone means that you have to push the suspension tighter up thru the swingarm, making the back end go up.
I think this is the way to explain this. I am sure others will have a better explanation. A picture is worth even more than this description.
0.2656888961792 seconds processing time
